  • 1994 - 1995 Specific Tech
MSD shift light
  • Thread starter Thread starter hollywoodstang
  • Start date Start date Nov 7, 2009
hollywoodstang
1,095
Nov 7, 2009
  • Nov 7, 2009
Hello Fellas
I just purchased the MSD shift light,and want to install it. It came with GMR pick up of some sort...There are 3 wires Red/Black/Green. I know red is power and black is ground and green is the tech, Do i use these 3 wires or GMR pick up on our cars? I have no clue and never had shift light in my car before or ever. lol
I do have digital 6 ignition, Do i hook this up with the green wire from the box or what? the shift light part # is 8963 from MSD, it's tiny light and i was thinkning about mounting it inside the vent.
Let me know
Thanks
HISSIN50
34
129
Nov 8, 2009
  • Nov 8, 2009
If your box has a tach output port, that'd be where you connect the trigger wire.
IIRC you use the GMR if connecting to the ignition directly. Since you'd be connecting to your box, it's not needed (be sure to confirm all this with MSD or in the instructions).
hollywoodstang
1,095
Nov 12, 2009
  • Nov 12, 2009
Thanks Hissin
There is no wire coming out of there...do i need to buy the tach adapter? If i do what is the part# for that?
Thanks
HISSIN50
34
129
Nov 12, 2009
  • Nov 12, 2009
Unless you run one, there won't be a wire coming out of the tach output port.
Have you looked at the instructions yet?
http://www.msdignition.com/instructions/Products/RPM_Timing_Controls/8963.pdf?terms=8963
hollywoodstang
1,095
Nov 12, 2009
  • Nov 12, 2009
i went and checked it out again and no. There is no wire coming out of it do i just get female connector that fits in and hook up the green wire to that tach output ?
Thanks
HISSIN50
34
129
Nov 12, 2009
  • Nov 12, 2009
Thanks
Sounds like a plan. Double check your box's instructions but IIRC they specifically mention using a Faston connector. Your female quick-connect should be fine. Try to solder it if you can.
hollywoodstang
1,095
Nov 12, 2009
  • Nov 12, 2009
Thanks Hissin
I will try it and test it if it lights up and do the things it suppose to do. I will report back if anything funky should happen.
D
shift light
  • dirk shorter
  • Dec 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 29, 2025
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
Electrical Fuse 8, Light Green / Black Wire
  • bleedinggreen
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 26, 2025
bleedinggreen
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
