MSD-Small Base Distributor
  • Thread starter Thread starter ravv 67
  • Start date Start date Jul 3, 2007
R
ravv 67
29
  • Jul 3, 2007
I want to put a monte carlo bar on my '67 without the distributor getting in the way. MSD makes this small base distributor that is 1 inch shorter and with a smaller diameter. Seems like the best fix since I was changing the distributor anyways and the cap is black(which I like).
Am I losing anything in performance by going with this small base. According to the description in summit catalog "performance is not sacrificed."
If not why wouldn't all of MSD's distributors be small?
dodgestang
1,360
Cecil County, MD
Jul 3, 2007
  • Jul 3, 2007
Spark scatter is more prone to happen with the smaller dizzy. Unless you have a high performance build I doubt you will have an issue like that.
R
ravv 67
29
  • Jul 4, 2007
Well I have a 302 that makes 385 HP at the fly. Do you think this small base pro-billet dizzy is fine?
Tim65GT
1,149
West Texas
Jul 4, 2007
  • Jul 4, 2007
I thought curved bars cleared most distributors, so height wouldn't be an issue.
If it's a straight bar, it would have to clear to top of the distributor and diameter wouldn't be an issue.
Anyone with a straight Monte Carlo bar with a MSD? (I'm getting one soon too and already have a MSD ready to run).
Or do we have to get a curved one?
R
ravv 67
29
  • Jul 5, 2007
You're right, a curved monte carlo bar will go around the dizzy regardless of the size, But when the bar starts to bend to go around it, it bumps into the a/c compressor. So if you don't have a/c the curved bar is the way to go.
66forfun
260
Pittsburgh
Jul 5, 2007
  • Jul 5, 2007
the larger dizzy is also pretty tall and could also have issues sitting under a 14" air cleaner so be warned.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 5, 2007
  • Jul 5, 2007
Having this issue with my friends Cougar. We put the regular MSD distributor in with a 14" drop air cleaning and now I'm having to do a lot of cuting to the air cleaner and I'll provably end up siliconing the bottem.
70dvr
46
Brandon, Florida
Jul 5, 2007
  • Jul 5, 2007
I use an air cleaner with a offset and drop base.(From Summit). Plenty of room for a straight bar.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 5, 2007
  • Jul 5, 2007
Damn, that would be way easier.... PAW didn't sell a drop base with an offset for a 4bbl, only for a 2bbl.
65fastbackresto
1,229
AR
Jul 6, 2007
#10
  • Jul 6, 2007
  • #10
Neutral safety switch
I removed the old tranny from my 65. Put in one thats more modern, but also a C-4. Pretty sure the wire for the neutral safety switch wont plug back in the newer tranny. Any easy ways around this problem? I`m running an MSD 6AL ignition, as long as it has power when the key is on, is this gonna work right?
Thanks in advance.
Edited, sorry guys ment to start new thread.....
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
20K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
Stiffer front springs writeup from the old .net site
  • LILCBRA
  • Oct 24, 2022
1974 - 1978 Mustang II Talk & Tech Oct 29, 2022
Enzio
M
Engine 87 Foxbody Hesitation at High RPMs
  • Matthewhh
  • Aug 6, 2020
7K
Fox 5.0 Mustang Tech Aug 11, 2020
08GT500
