MSD wiring question
  • Thread starter Thread starter Jon22
  • Start date Start date Sep 23, 2006
J
Jon22
25
Marietta, GA
Sep 23, 2006
  • Sep 23, 2006
I have an MSD ready to run distributor on my 65 289. I have it direct wired off of the starter solinoid "I" terminal. I have 12 volts with the key on but only 8 when running. Any advice on the best way or place to tap 12 volts on these cars? I am also going to add a 6AL box later. Any help would be appreciated.
Thanks, Jon
Max Power
1,774
St Paul
Sep 24, 2006
  • Sep 24, 2006
Put a 6AL in now. That way the 8v won't be a problem. Why wire it differently twice?
The wiring diagrams are on the MSD website.
J
Jon22
25
Marietta, GA
Sep 29, 2006
  • Sep 29, 2006
So, does that mean that you wire the 6AL to the battery and use is switched 8 volts for the distributor? MSD says you need a switched 12v even with the box. Any advice or info on how someone has wired one of these things would be appreciated.
Great68
691
Victoria BC
Sep 29, 2006
  • Sep 29, 2006
Thanks, Jon
I just removed the ballast resistor wire in the car.
Made a world of difference with my ready-to-run, cleared up a 5000rpm misfire once it was getting full 12V.
Max Power
1,774
St Paul
Sep 29, 2006
  • Sep 29, 2006
Dwonload the 6AL instruction from the MSD site. I remember them saying you can use the resistor wire feed as it is. I am using it and it works great up to 6500rpm.
Great68
691
Victoria BC
Sep 29, 2006
  • Sep 29, 2006
I guess experiences may vary.
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
