  • SN95 4.6L Mustang Tech
Musical Mustang
  • Thread starter Thread starter SpitfireMk24
  • Start date Start date Nov 30, 2004
SpitfireMk24
140
Livermore, CA
Nov 30, 2004
  • Nov 30, 2004
Hey Ive been hearing a bunch of wierd sounds from my car. . .
first of all, the fog lights button, in the center console above the shifter, it resonates and buzzes when the engine is over about 1500 rpms. . . it bugs me.
also, when I am driving slow, and i accelerate in 1st, and let off the gas the tranny makes an odd whining noise as the car slows. . .
when I am driving slow, and I shift into fifth gear, at like 45 mph, if im too quick with the clutch the car kinda jerks back and forth, right? well when this happens, I hear a clicking somewhere in the drivetrain somewheres between the engine and the diff. . . like maybe driveshaft bolts are a little loose? whatever it is Im getting it checked out quick!
does anyone else experience these sounds? are they bad, or possible to get rid of?
Tom in Tacoma
74
Dupont, WA
Nov 30, 2004
  • Nov 30, 2004
first of all, the fog lights button, in the center console above the shifter, it resonates and buzzes when the engine is over about 1500 rpms. . . it bugs me. - Fix it!
also, when I am driving slow, and i accelerate in 1st, and let off the gas the tranny makes an odd whining noise as the car slows. . . Stop doing that if it bugs you - it's gear noise is all
when I am driving slow, and I shift into fifth gear, at like 45 mph, if im too quick with the clutch the car kinda jerks back and forth, right? well when this happens, I hear a clicking somewhere in the drivetrain somewheres between the engine and the diff. . . like maybe driveshaft bolts are a little loose? whatever it is Im getting it checked out quick! Stop doing that as well. At 45 you're really not turning enough RPMs to get off the clutch in such a tall gear.
Any other annoyances we can take care of for you?
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
Nov 30, 2004
  • Nov 30, 2004
the downshift whirring is normal, and sounds kinda cool imo
SpitfireMk24
140
Livermore, CA
Nov 30, 2004
  • Nov 30, 2004
I think 45 is plenty fast, seeing how the owners manual says 40MPH is the best place to shift into 5th for fuel economy. about the button, I was wondering if anyone had the problem, and/or fixed it, and how.
I wasnt asking for a flaming, I was asking if anybody had these problems, and what they did about them. It doesnt seem like youve had any of these.
btolenti
277
Gilroy, CA
Nov 30, 2004
  • Nov 30, 2004
I have major dash rattle from the piece around the stereo and climate controls. What I did was remove it and slather show goo at all the joints.....sound is gone now!
I have the 5th gear "problem".... It's not really a problem if you let the clutch out a bit slower. I think this is normal. It is a tall gear that shouldn't be shifted into fast if you are going that slow....
Tom in Tacoma
74
Dupont, WA
Dec 1, 2004
  • Dec 1, 2004
Careful now - you might end up getting a thumbs-down for that kind of thinking...
SpitfireMk24
140
Livermore, CA
Dec 1, 2004
  • Dec 1, 2004
how do you remove those big peices? they seem to be glued on!
and about fifth gear, im not shifting real fast, im just still catching onto the finer points of driving manual, and Im not always so smooth. Its not only with fifth gear though, whenever the car jerks forward and back, that sound. . . its almost sounds like the driveshaft is gonna fall off!!
btolenti
277
Gilroy, CA
Dec 1, 2004
  • Dec 1, 2004
SpitfireMk24 said:
how do you remove those big peices? they seem to be glued on!!!
Just give it a good tug, and it will come off. It's held in by a few clips.
Sounds like you need to keep the rpms up a bit more between shifts. When you shift between gears you need to feather in some gas.....basically, you want to match the engine rpms with the rpms of the rest of the drivetrain when you let the clutch out. If not you will get the jerking because you are trying to connect two seperate pieces of the drivetrain together that are moving at different speeds... Hope that makes sense.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Dec 1, 2004
  • Dec 1, 2004
The 5th gear thing is common. It sounds like a clunk and its in every stang from a v6 to the almighty terminator. I believe its called drivetrain slack and can be avoided by simply shifting at a little higher in the rpm range in 5th.
SpitfireMk24
140
Livermore, CA
Dec 1, 2004
#10
  • Dec 1, 2004
  • #10
drivetrain slack sounds like a good way to describe it. . . do you think its up in the tranny or back towards the differential?
it sounds so bad though! Id rather everything fit together tightly, you know?
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Dec 1, 2004
#11
  • Dec 1, 2004
  • #11
Its a FORD hahaha, so not gonna happen!
merc123
420
North GA
Dec 1, 2004
#12
  • Dec 1, 2004
  • #12
I had my driveshaft retorqued and reindexed. Two days latter the "slack sound" (AKA clunk) came back. Had the 3650 TSB done. Fixed the clunk for a week, came back. It will never go away and essentially Ford's TSB on the clunk says that it's normal and that it's from driving wrong. I can get the car to NOT do it ONLY if I slip the clutch really slowly when shifting gears. I just live with it.
btolenti
277
Gilroy, CA
Dec 2, 2004
#13
  • Dec 2, 2004
  • #13
I have heard that it is because Ford sets up the rear end gears looser than they should be....
merc123
420
North GA
Dec 2, 2004
#14
  • Dec 2, 2004
  • #14
That's what my Dad thinks. We jacked up the rear one time and rolled the wheels by hand to see where they "lock" gear to gear. There is about 1/2" of free play in the wheel which translates to free play in the lash setting of the rear end. I told Ford to readjust the lash but I don't think they ever did.
F
FalconGuy016
437
Northern VA
Dec 2, 2004
#15
  • Dec 2, 2004
  • #15
Doesnt sound like anything is wrong, if you are still learning manual. It will make a lot of weird noises until you master the clutch.
Premium Speed
1,006
Houston, Texas
Dec 2, 2004
#16
  • Dec 2, 2004
  • #16
we have a winner...
don't worry too much about it...
SpitfireMk24
140
Livermore, CA
Dec 2, 2004
#17
  • Dec 2, 2004
  • #17
Premium Speed said:
we have a winner...
well, I wouldnt, but then I see images of me at a stop light, about to humliate a honda, and the light goes green, I launch, and my driveshaft falls out . . .
btolenti
277
Gilroy, CA
Dec 2, 2004
#18
  • Dec 2, 2004
  • #18
I don't think it's that loose.....
And if it was, I would think you would chip the ring or pinion gear before shearing the driveshaft tube or blowing a u-joint...
SpitfireMk24
140
Livermore, CA
Dec 2, 2004
#19
  • Dec 2, 2004
  • #19
yeah I talkted to the ford dealer service guy, he called it gear rollover and said dont worry about it. . .
btolenti
277
Gilroy, CA
Dec 2, 2004
#20
  • Dec 2, 2004
  • #20
Yeah, because when it breaks, after your warranty, they can fix it and charge you an arm and a leg - literally...
Oh well, it gives us mustang owners a good reason to regear to 4:10!
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Saturday at 9:08 AM
SchwarzStock
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
