Usb_Port said:
Good to know, thanks for your input everyone! 230 RWHP on a mustang dyno = aprox 264 on a dynojet. I sure noticed a difference from the tune, felt like more than 10 hp!
Just a little FYI. I started with the generic SCT 89 oct tune and dynoed at 221, the guys tweeked it out over 5 or so pulls to get it to 230. Dyno tune is definitely worth it even on a stocker.
Dont count on that...people like to lable a % on the difference, but thats just not the case, and is extremely innaccurate.
Dyno jets load EVERY car for the same weight (I believe 2000#s) and take 0 aerodynamics into account.
the mustang dynos #s will VARY depending on what weight the dyno operator enters into the machine. Mustang dyno #s vary greatly accross the board...and that depends on who is operating the dyno. In theory, since it is taking aero into accont....different gear rations will effect HP #s more since the drag increase or decreases dependant on which gears you have (4th gear pull will result in different MPH with different gears).
Basically there are just way the heck to many variables with the mustang dyno to estemate dynojet #s. No % difference, unless all variables were always the same and you knew them...which is practically impossable anyways as each varibale effect #s by X amount....and you would have to find X for each variable
. Just throw it on a dyno jet to see what your #s are.
And remember your RWHP will be less on the dyno jet now, vs if it were tuned on a dyno jet. Why? Becaue the dynojet loads to 2K#s...that puts less load on the engine, and makes it run richer throughout the dyno pull. Thus less RWHP.
Generally a dynojet tuned car will walk a mustang dyno tuned car (say both equal engines @ 13-1 AF) because on the street the dyno jet car is running a little leaner. (re slightly more HP) This is in theory, and what I have seen/heard.
