  • 1994 - 1995 Specific Tech
Mustang help? Please!
  • Thread starter Thread starter mustang32cobra
  • Start date Start date May 7, 2009
M
mustang32cobra
  • May 7, 2009
I have a 1994 ford mustang cobra. A couple of months ago the rpms started surging and the car cuts out when at idle acceleration and at crusing speed. This is my first car and i can not find out what is wrong with it and i dont have a check engine light on and cant have a test done on it cause i dont have a cadillac converter instead i have a off road h-pipe. I have replaced the fuel filter, spark plugs and wires, mass air flow sensor, O2 sensor, TPS sensor. And i also checked the fuel injectors and fuel pressure and are all working fine. And also all the pressur is normal in the engine. I dont know what to do and my brother is in iraq and cant help me. So please if someone has any advice that can help!
Thank you for your help and your time,
Spencer
94-302-vert
1,947
NE CT
May 7, 2009
  • May 7, 2009
Spencer,
Welcome. You have jsut found betst group of guys (some gals) that know a TON about mustangs.
Please make a sig with your mods (if any) as they will help to diagnose. Also put in your location as many times a local stanger can stop by to help.
Based on what you are saying I would suspect that your fuel pump is on the way out. It is pretty common. What is the age of the car (miles) and has the pump ever been changed that you know of?
M
mustang32cobra
  • May 7, 2009
It has about a 150,000 miles on it and i just got the car from my brother that was shipped to iraq so i have no idea. But my guess would be that is hasnt. do you know how much a new fuel pump would run?
94-302-vert
1,947
NE CT
May 7, 2009
  • May 7, 2009
Pumps are about $100 and a few hours to change yourself. Not the cheapest thing but with everything else you have already done it definitely fits with the equation.
Most will say to buy a pump the size you will ever need. Many times this means a 255lph pump. You can get them at summit, jegs, or almost anywhere. I would suggest Summit as thier service has always been great to me.
donkey_punch
565
northern****ingjersey
May 7, 2009
  • May 7, 2009
sounds like the classic stator in the distributor is crapping out.
spencer, when it dies is it hard to start?
Dino Dino Bambino
1,672
89
79
Cyprus
May 7, 2009
  • May 7, 2009
Agree and since they're heat sensitive, stator failures are occurring more frequently now that the weather's getting hotter (mine included).
shttygtstang
978
  • May 7, 2009
B4 throwing parts at it there are was to test things. Like what is the vac at idle , fuel pressure at idle and when its going down the road . TPS reading you just dont throw parts and hope to get lucky.
Learn abought how the motor operates ,what sensor do what and how you can trouble shoot them. then pick your car apart.
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
