Mustang help
  • Thread starter Thread starter Nibbie
  • Start date Start date Mar 10, 2007
Nibbie
127
  • Mar 10, 2007
yesterday i was driving my car and i happend to run over a new garden hose all coiled up, i dragged it for 4 blocks but didnt think nothing of it, then i went and put gas in it and continued to drive. after a while the car started surging like crazy and bogging and just bucking back and forth, put it in neutral and it wanted to die. i dont know if i got bad gas or if i messed somthing up by running over the garden hose. I took the car home and let it sit for a while, tryed to start it and it would not start. cleaned out my mas air meter and IAC, it wouldnt start so i let it cool down, then i started fine, i drove it for about 10 minutes and the car was getting warm and started surging and bogging again. It seems like it will only do it when it sits for a while. I dont know whats going on and i need some help.
90 mustang lx 5.0 (5spd)
grannatelly mass air meter
underdrive pullies
CAI
Performeance Distributers igniton kit
Fidanza aluminum flywheel
centerforce 2 clutch
FRPP aluminum driveshaft
rebuilt T-5
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 10, 2007
  • Mar 10, 2007
If you want someone to tell you to replace some $13 part and your problems will be all cured, it isn't going to happen. You have an intermittent problem that only happens when the engine gets warm. That means you are going to have to troubleshoot the problem when it happens. Troubleshooting takes time and perseverance: throwing parts at it will just make you tired and poor.
Here’s the diagnostic test path:
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is less than $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 20-Jan-2007 to include TPS voltage out of range fault.
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
J.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) 86-93 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running. If fuel is coming out the vacuum port, the regulator has failed.
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage. It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
HISSIN50
34
129
Mar 10, 2007
  • Mar 10, 2007
Dare we ask where the hose got sucked up that you think it caused a drivability issue?
After doing as JRichker suggested, you should have a better idea of what's going on. Note that you need to have the car act up for the testing to be valid.
Good luck.
Nibbie
127
  • Mar 10, 2007
lol no, the hose was burning on the exhaust and i had to grab it and take it out from under the car, i was only thinking if it hit a wire on my o-2 sensor. thanks for the advise and ill try that.
R
red95gtconvert
382
Ponca city, OK
Mar 10, 2007
  • Mar 10, 2007
I think you answered your own question, I would definatley look into the O2 sensor situation.
Nibbie
127
  • Mar 11, 2007
yea i guess im an idiot like that. lol
but i guess there is to manythings that could go wrong and make a problem like that. o2 sensor, coil, things like that. grabbed a scanner from work and my codes where
11, 67, 18, 87. the others are usualy normal except 87-that mentions somthing about fuel pump wiring/inertia switch, but i never triped the switch so i have to look into that also. but anyway thanks for the help .
HISSIN50
34
129
Mar 11, 2007
  • Mar 11, 2007
After you check your wiring under the car......... I believe you have a PIP code, and given the issue you're having, I'd be all over that.
Jrichker will have more info on your codes in the early morning.
Good luck.
Nibbie
127
  • Mar 11, 2007
whats a pip code?? yeah i checked under the car and the o2 sensors and the wiring all look fine. but the passenger side o2 has a slight dent in it. i started it this morning it ran fine, got to normal operating temp and died again. Im going to pull codes again just to make sure. thanks for the help.
M
Mike85000
65
  • Mar 11, 2007
If it runs fine cold, but when warms up it dies it could be two things in my mind. Either an electrical device is failing when it reaches temp (maybe TFI module??) or once the computer gets out of closed loop, something bad happens causing the problems.
Nibbie
127
#10
  • Mar 11, 2007
  • #10
my thoughts excactly, i just scaned it again, low temp with a snap on scanner, did a koer test before it died reaching normal operating temp. i got so far is a 11, 67, 18, 87, and 21-(ect out of range/posably from running the test while engine not at operating temp) these stupid problem is driving me insane. im trying to figure out if bad o2 sensors or ect sensor will cause the engin to die when warm.
I swaped out coils with another vehicle to check if that would be the problem but still happens, well at least thats out of the way. lol anymore sugestions? thanks
Nibbie
127
#11
  • Mar 11, 2007
  • #11
how would i permenantly keep the car in closed loop to drive it to work with out it dying in me???
HISSIN50
34
129
Mar 11, 2007
#12
  • Mar 11, 2007
  • #12
As long as your heating element on the O2's works (it should), the car goes into closed loop within about 2 minutes (or less) after start-up.
When it dies, if it wont start, check for spark and injector pulsing. If you are missing both, the PIP is likely.
If missing just spark, the TFI (their critical temp is ~257*F when healthy, less when not) or coil are likely. You can test across the electrical wires going to the coil to see if the TFI is sending a ground pulse to the coil.
Good luck.
Nibbie
127
#13
  • Mar 11, 2007
  • #13
FIXED i checked the coolant temp sensor and that was with in spec, then i went to the modual and checked that out. didnt look so good, so i went to autozone and got a new ignition mod and now it will stay on when warm woo hoo, thanks for everybodys help :SNSign:
P
paulfm5.0
#14
  • Mar 12, 2007
  • #14
same problem
i'm having the same exact problem with the car cutting out at operating temp so i replaced the TFI/Ignition Control Module and the problem still exists, what else can i check
Nibbie
127
#15
  • Mar 12, 2007
  • #15
well i checked the coil, checked resistance in my coolant temp sensor, spark plug wires, distrubitor cap and rotor. and made sure my o2 sensors where pluged in and ok. runs ok now but loss of power since the modual is differnt from the one i had. but try getting codes out of it 1st so you dont waist your time on checking a bunch of things like i did.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
