Mustang Shock Tower Repair
dbdragracing
397
I just went to look at a 1991 Mustang GT (really nice...selling due to a divorce). The car is great except for the driver side shock tower has a hole rusted in it just below the brake stuff...how hard is this to fix and can it be done with the engine in the car? Are the parts readily available? Thanks for any help...I think I can get the car for $1500. Later.
it would be easier to fix with the engine out but maybe you could rig it some how for the time being.... I would burn the rust out and fill it with lead it its not too big. Other wise you will have to patch it with steel.
like 7-up stated some pics would help. My buddy had teh same problem but his was caused by unequal length headers burning the paint off and causing a rust hole. we where able to fix it with the motor in the car, we pulled the header off and motor mount, tilled the motor and cut out the area and welded a patch in. It's tight but can be done.
They don't make replacement towers but if it's really bad ( I have seen some) you would cut out a tower section from a junk car and weld/graph it in, a job for pro's.
Very true, it really is a job for a pro.
Depending on the location of the rust and the amount, it would be hard to fix the shock tower with the engine in. But, not impossible! Again, it depends on where exactly the rust is.
For example, I folded and welded the back portion of my strut tower to fit in my booster. That was with the engine in the car. But, obviously, no booster or other stuff in that area.
http://www.veryuseful.com/mustang/joe/brakes/graphics/bumpForPowerBooster2.jpg
You may be able to get to it by just taking off the wheel, using some sandpaper to clean up the area, and put a patch on from there.
If it's minor (which it sounds like), then you're really doing a cosmetic fix and to prevent any further rusting. In that case, I suggest using epoxy putty. You'd make a "plug" that went over both sides. You'd want at least 1/8" think in the engine bay, and then 1/4" to 1/2+" think in the wheel well (where it wont show as much).
Note: Regardless of the BS that you may have read, the strut towers FLEX A LOT! That's been know since the 50's! Strut tower braces are not new. So, if the hole is too big, then the non-flexing epoxy patch isn't a good idea.
FYI:
Epoxy Putty Web page - Oatey.com
Epoxy Putty Web Specs:
http://www.oatey.com/apps/catalog/instance_assets/assets/Submittal_Sheet/Epoxy Putty.pdf
Old package:
New package:
BTW: There are many different epoxy putties. I like the above because it works well and you get a bigger stick for the price. Of course, JB weld also makes one:
J-B Weld Company - J-B STIK Product Information
Properties (psi)
Tensile Strength: 6,000 psi
Density: 15.8 lb/gal
Compression Strength: 14,000 psi
Shear Strength: 700 psi
Hardness: 75-85 psi
Resistant to: 300° F
Modulus of Elasticity: 6 x 105 psi
i my 93 project, i cut all the bad metal out, replaced it with 1/4" plate. also plated up the front of the tower and plated into the subframe. i want NO flex. i did this on both sides. i am going to use fiberglass to finish smoothing the engine bay, so you wont see the hideous plate steel there.
Thanks for the help guys...took the car to the restoration shop today and he told me to remove the engine and he would fix it for $200! So I bought the car for $1500 due to the guy getting a divorce!
$200 not bad, I PM'ed a guy on here and he paid $1200 to have his fixed with the engine in.
Hopefully I'll be doing mine soon since I have the same problem like many others. I wish they made replacement strut towers for foxes.:shrug: I noticed in the junkyard that the SN95 are showing the same signs of strut tower rot.
My driver side is the same way...need to cut it out and have it fixed.....foxes are known for that.....my buddies 94 dont have a spec of rust..but his shock towers were rotting from the inside out.....bad design from the start from ford with them
