I followed the checklist on this forum that jrichker wrote, and am a bit stuck. I also have a 92 LX 5.0. The car was running along just fine then out of the blue, died and has not restarted since. I have good spark, because if i spray ether in it will run for about 5 seconds before it runs out of fuel and dies, tested fuel pressure to the rail and pressure is good. Things I have noticed are that with the ignition on, the fuel pump never stops priming, and when trying to crank the car, a Noid light installed on 1 of my injector wires gives no light at all. Is it likely that the problem is the PIP sensor even if I am getting spark? Was recommended to me to replace the TFI, but if the TFI was bad, I would expect no spark, not no injection functionality. Any input would be greatly appreciated. Already have replaced parts that weren't the issue, and with the weather getting nicer, I really want to get this monster back on the road! Thanks in advance!
PS. I know the checklist says PIP sensor could be the issue if injectors aren't firing, but would I also get no spark if the PIP was bad? Or is it possible for it to allow 1 circuit to work but not the other since it is partially responsible for both. Thanks!
