mustang won't start
  • Thread starter Thread starter carracer76
  • Start date Start date Oct 27, 2010
C
carracer76
20
  • Oct 27, 2010
I just pullied out an old code alarm system my 89 gt. Everything came out fine but the car will not turn over, I can not figure it out. I have power but it dosent turn over.
HISSIN50
34
129
Oct 27, 2010
  • Oct 27, 2010
The starter interlock circuit is interrupted on most alarms. Do you remember removing a relay/relay socket on the white/pink wire? The relay socket probably had a diode across the coil terminals if that stuck out in your mind.
C
carracer76
20
  • Oct 27, 2010
wire
There was one of the wires from the alarm spliced into it but I removed it.
HISSIN50
34
129
Oct 27, 2010
  • Oct 27, 2010
Starter interrupts function by cutting the wire and running it through a relay. You should find the wire to have been cut along its run.
If you go to your starter solenoid and put a test-light on the little wire at the top of the solenoid, does the light illuminate when trying to start the car? If not, go to the clutch switch and test the both terminals the same way. If the light doesn't ever illuminate, you need to trace the wire back towards the ignition switch.
C
carracer76
20
  • Oct 27, 2010
mustang
were is the clutch switch located?
HISSIN50
34
129
Oct 27, 2010
  • Oct 27, 2010
Look at the top of the clutch pedal's arm.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 28, 2010
  • Oct 28, 2010
No Crank checklist for 5.0 Mustangs
Revised 05-Oct-2010 to update Fluke references.
No crank. slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of both no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a know problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstuck and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .5 volts across a connection indicates a problem.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
C
carracer76
20
  • Oct 28, 2010
mustang
I tried jumping it, did not work. Whats keeping it from getting power to the coil, I have power to the ignition. When I put the tester on the selinoid and tried starting it there was no light. I have MSD ignition.
C
carracer76
20
  • Oct 28, 2010
The car started fine. Soon as I removed the old codealarm system its just not turning over.
HISSIN50
34
129
Oct 28, 2010
#10
  • Oct 28, 2010
  • #10
If it doesn't turn over, power to the coil is not the issue.
Using the suggestions and tech notes on this thread will help you find the solution.
Good luck.
C
carracer76
20
#11
  • Oct 28, 2010
  • #11
Thanks fellas I will try
C
carracer76
20
#12
  • Oct 29, 2010
  • #12
mustang
Ok, I jumped the solenoid and the car strarted, then I bypassed the ignition wire to the solenoid and it started.. So the one wire to the solenoid was from the clutch switch, what should i do with this wire. Now the ign wire red/green comes out of the firewall and is connected to a small wire that that jumps over to a smaller red/green wire into the wire harness that runs back along the firewall.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
  • brandyn200
  • Jun 20, 2026
AeroCoupe
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
