My 1994 5.0 GT has vibration/shakes at idle and all speeds
icemik1
Hello all. I have a 1994 GT, it vibrates/shakes at all speeds even at idle.
It feels like its coming from the rearend are but at the same time it feels like the motor is not balanced. Any one have this issue before.
Thanks.
Is there anyway to tell for sure without removing it?
couple of ways
With motor running- look at HB and see wobbling (how I found mine)
With motor off- from the ground looking up, look for rubber squeezing out of HB on the oil pan side
With motor off- verify timing. #1 on tdc, make sure timing pointer is pointing at 10*btdc (or what ever you have base timing set to.
You may only have 1 sign or all of them.
couple of ways
My thoughts exactly as well. :nice:
Man being honest with you it could be all of these... is it likely... maybe...maybe not... first off eliminate the easyiest to check first pop the hood and get a buddy to cycle from drive to reverse (on a manuel jus throw it in netural and get hard on the gas and watch for *excessive* movement) and if the engine lurches bad you got a bad motar mount
