My $2000 Ignition - I need help!
  • Thread starter Thread starter wahoo23
  • Start date Start date May 12, 2008
  • 3
  • 4
First Prev 4 of 4
Tim65GT
1,149
West Texas
Jun 5, 2008
#61
  • Jun 5, 2008
  • #61
wahoo23
Tonight, I connected the red MSD wire to the I terminal of the solenoid. The red MSD wire is also connected to the ACC post of the ignition switch. It now fires right up. I'm a little confused why this would work - shoudn't the coil be getting power in the start position with the ACC connection?
You should probably move the Ignition switch connection from the ACC post back to to the Red/Blue Coil "C" wire.
If you have the key turned to the "ACC" position, for instance to sit and listen to the radio, the MSD box is also powered and will drain the battery faster.
jcode68
892
Massachussetts
Jun 5, 2008
#62
  • Jun 5, 2008
  • #62
Just to clarify, I think he means red with green stripe wire. Already enough confusion in the thread
BarnStang
1,260
Hagerstown, MD
Jun 5, 2008
#63
  • Jun 5, 2008
  • #63
Tim, thanks, that was probably one of my poorer ideas. It was easiest...fastest. But should not have been a permenent fix.
Oh, wahoo, in my post at the end where I said ...won't get the coil hot enough, I was refering to the coil in the electric choke housing.... yes, too much confusion already-most from me. Thanks for your patience.
wahoo23
63
Parker, Colorado
Jun 6, 2008
#64
  • Jun 6, 2008
  • #64
Thanks to all for your help getting me through these issues. All that's left is to dial in the timing... One final question, somewhat unrelated - the MSD "chirps" - is that normal, or an indication that something is not quite right? Car runs ok, hesitates somewhat when you punch it, but otherwise is ok.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jun 6, 2008
#65
  • Jun 6, 2008
  • #65
I have a digital 6 msd box and I don't think I've ever heard mine chirp... What do you mean by chirp ?
wahoo23
63
Parker, Colorado
Jun 6, 2008
#66
  • Jun 6, 2008
  • #66
Have you ever tested the spark at the coil by disconnecting the lead from box to dizzy, laying the wire from coil to dizzy on a ground, and shorting out the purple and green wires of the lead from the box? The coil chirps. It does that constantly, but not regularly. By regularly, I mean in a pattern. Maybe I'll try to get a sound clip this weekend...
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jun 6, 2008
#67
  • Jun 6, 2008
  • #67
I thought you were saying the box was chirping not the coil. I don't remember my coil ever chirping either tho.
wahoo23
63
Parker, Colorado
Jun 6, 2008
#68
  • Jun 6, 2008
  • #68
Sorry, the coil is also MSD, I should've clarified.
RGS0907
429
New Jersey
Jun 9, 2008
#69
  • Jun 9, 2008
  • #69
Boy, this thread makes me look back fondly on my dual points.
  • 3
  • 4
First Prev 4 of 4
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
  • brandyn200
  • Jun 20, 2026
AeroCoupe
