pb_paulie_b said:The only disadvantage to this set up over going with a small base circle cam/spider hold down set up is that you wont be able to remove the lifter without taking off the heads.
as far as i know, only crane makes the linked bar hyd roller.pb_paulie_b said:Crane, Comp, and Crower all make these lifter for that purpose.
not an issue with the taller windsor blocks.The only disadvantage to this set up over going with a small base circle cam/spider hold down set up is that you wont be able to remove the lifter without taking off the heads.
You have a set of Crane link-bar hyd.roller lifters on a non-roller block?bluevenom867 said:I had Crane hyd. rollers and they came out with the heads on?
I'm sorry I got the 5.0 and 351w mixed up, you CAN remove Crane lifters without removing the head.paul302 said:as far as i know, only crane makes the linked bar hyd roller.
the comp cams & crower parts you listed are just standard replacemnet hyd rollers. they're not the linked bars that allow you to use a standard hyd roller camshaft.pb_paulie_b said:These are the lifters I was referring to earlier.
Comp cams part# 851-16
Crower part# CRO-66335-16
Crane part# 36532-16
Ford racing# M-6500-S58
yep, there's still standard non-link bar lifters. the pic on the summit page is just a generic pic, it's not representitive of the actual part. go by the price. you're NOT going to buy a linked bar hyd roller for $200. if you still doubt me, call crower and comp to verify for yourself.pb_paulie_b said:Heres a link to the Crower parts,
http://store.summitracing.com/default.asp?target=egnsearch.asp&N=115+400401+307693&autoview=sku
Comp cams,
http://www.fordmuscle.com/blog/roller-cam-conversion-made-easy/11234
your summit page must be showing something different than mine.pb_paulie_b said:Paul302, they are on the same page in the link I provided. Scroll down.
$577![]()
those are the ones i run. can't go wrong there.pb_paulie_b said:I personally am goin with Crane ones on my build...
pb_paulie_b said:You have a set of Crane link-bar hyd.roller lifters on a non-roller block?
