I have a 1985 Tbird 5.0 that I've converted to a 5.0 HO. It's running a 1989 mustang harness with Mass Air and a A9P computer. The problem I've had since I put this car together is that it's always running in open loop (if I disconnect the mass air sensor, nothing happens). When the engine starts in the morning, it runs fine for a couple of minutes (although by the smell of it, it runs rich—but this might be the case for everyone since its cold). Then as it get closer to operating temp, it starts to misfire and run like crap. It continues to do that for a few minutes, whether I'm stopped or trying to move down the street. After a while, it runs smooth and drives strong—except it still runs rich. My guess is that the computer stutters and convulses when it's trying to go into closed loop, but after a while it just gives up and stays in open loop. There must be a sensor(s) that's not feeding the correct info to the computer, but I don't know which one(s). I admit that it could be a sensor(s) itself or a wiring problem because the harness was acquired from a junk yard wreck. I'm wondering if I can use a multimeter and probe the various prongs at the eec while the car is running to figure out what's going on, OR is there a shop computer that could do this quickly and easily. I have a couple of mustang only shops near me: Chicane Motorsports in Torrance, CA and GTR High Performance in Rancho Cucamonga, but I've had no experience with either place.
By the way, the computer is not throwing the “Check Engine” light at all, unless I disconnect the Mass Air connector. I have done a KOEO test and it does produce two or three codes, but I haven't done it in a long time and I don't remember what they are right now (it's 12:30 a.m.). But when I did do it, the codes were not helpful to me in finding the answer to this problem. (maybe I'll do it again soon, and post them).
Thanks for any input!
