MY 5 LITER IS NOT FWD
cmb91LX
432
Memphis
Here is my problem. I have a 91 LX and there is a popping noise coming from the front end. It feels and sounds exactly like a FWD car does when the CV joint is going bad, it pops when the steering wheel is being turned under slight acceleration. What the heck is this? It is seriously getting on my last nerve as I have checked all kinds of things on the front end. :bang:
check both the ball joints and rod ends. i actually tore a balljoint right out of the a-arm by letting them go too long after they started making noise. i figured i could get away for a little while. luckily i was only going 30mph when it happened......... :nonono:
freind of mine snapped a tie rod on his focus that had been cracked from his brother for about a year funny thing is they took the car to the KEYS and back to va but the tie rod gave up in the parking lot at his school. can you imagine what would have happened if it would have let go on the highway???????????????????????!!!!!!!!!!!!!!!!
OK, I have gotten under the car and shook each of the end links and grabbed the tires and there is no play, which would be symtomatic of a ball joint right? I have grabbed and pullled on the end links and no play, no cracks in the bushings, etc. Is this something anyone has encountered before and it ended up being ball joints, end links etc? It feels just like a bad CV joint which leaves me puzzled :bang:
some times no matter how hard you grab, pull, or tug you're not going to be able to exert the type of force that is required to to get that part to make the noise your looking for.
your car is after all 13 yrs old, it may be time to start changing some of the parts listed in the other posts.
If you want to check ball joints all you need to do is:
1. Lift the car by the frame high enough for the wheel(s) to be off the ground.
2. Grab the wheel with your hands- one hand at 2:00 and the other at 7:00.
3. See if you can wiggle the wheel. If there is any play you probably have a bad ball joint. Sometimes you may feel bad wheel bearings too but you will know if its the ball joint. You can also change hand positions- there should be no play at all. If there is something is wrong.
I have done something similar to check. I have left the car on the ground and grabbed the wheel and shook real hard and there is a little play/ knock when the real is rocked out to in. It felt as though the wheel itself was loose, and after tightening the wheel it still has a litlle play. I will try to jack it up and do what you guys have suggested.
