My 91 is running terrible, could use some help
Got my plug wires in today just early enough that I was able to throw them on. Car runs smoother in the upper rpms (2K+), but still seems to run rough at idle, in fact, I swear I can smell raw fuel in the exhaust now. I went out and ran it up and down the street to get it up to temp. I pulled the KOEO codes and got code 34 twice in a row after getting code 11.
Well, I assume I'm getting code 11, it throws four 1's in a row, like it is reading 11, pause, 11. It has done this from the get go and I forgot to mention it, dunno if it is relevant or not.
If it's idling rough, the CBT should help narrow it down (I'd run it again). The CBT does not test injectors - it notifies you which cylinder(s) are not contributing properly. The cause can be a myriad of items other than the injector.
As a side note, I've still been leaving the battery disconnected when I am not working on it, this may/may not have an impact on how it is running since I have not gotten any miles on it since I put it down a month ago.
Well I bypassed all the smog vacuum related lines that were not connected, and ran a new vacuum line from the manifold to the EGR valve. Still runs rough at idle, surges a bit on decel, and run rich. Got the car up to temp and did the KOEO/KOER/CBT tests and got all the same codes (94, 44, 34, and 9 on the CBT), fused the fan so I can leave the battery hooked up. I disconnected the MAF, and it seemed to run the same at idle and 2K. I pulled the MAF off and looked at the sensor, doesn't look dirty (like I'd be able to tell anyhow). I'm guessing it is bad or I need to clean it. What can I use to clean the sensor?
Thanks
It sounds like you have the EGR incorrectly plumbed...
Some basic theory to clarify how things work is in order…
EGR System theory and testing
The EGR shuts off at Wide Open Throttle (WOT), so it has minimal effect on performance. The addition of exhaust gas drops combustion temperature, increases gas mileage and reduces the tendency of the engine to ping. It can also reduce HC emissions by reducing fuel consumption. The primary result of EGR usage is a reduction in NOx emissions.
The EGR system has a vacuum source (line from the intake manifold) that goes to the EVR, computer operated electronic vacuum regulator. The EVR is located on the back of the passenger side shock strut tower. The computer uses RPM, Load. and some other factors to tell the EVR to pass vacuum to open the EGR valve. The EGR valve and the passages in the heads and intake manifold route exhaust gas to the EGR spacer (throttle body spacer). The EGR sensor tells the computer how far the EGR valve is open. Then computer adjusts the signal sent to the EVR to hold, increase or decrease the vacuum. The computer adds spark advance to compensate for the recirculated gases and the slower rate they burn at.
attachment.php
Troubleshooting:
There should be no vacuum at the EGR valve when at idle. If there is, the EVR (electronic vacuum regulator) mounted on the backside of the passenger side wheelwell is suspect. Check the vacuum line plumbing to make sure the previous owner didn’t cross the vacuum lines.
Diagram courtesy of Tmoss & Stang&2birds. (the diagram says 88 GT, but the EGR part is the same for 86-93 Mustangs)
The EGR sensor is basically a variable resistor, like the volume control on a radio. One end is 5 volt VREF power from the computer (red/orange wire). One end is computer signal ground (black/white), and the middle wire (brown/lt green) is the signal output from the EGR sensor. It is designed to always have some small voltage output from it anytime the ignition switch is the Run position. That way the computer knows the sensor & the wiring is OK. No voltage on computer pin 27 (brown/lt green wire) and the computer thinks the sensor is bad or the wire is broken and sets code 31. The voltage output can range from approximately .6-.85 volt.
The EVR regulates vacuum to the EGR valve to maintain the correct amount of vacuum. The solenoid coil should measure 20-70 Ohms resistance. The regulator has a vacuum feed on the bottom which draws from the intake manifold. The other vacuum line is regulated vacuum going to the EGR valve. One side of the EVR electrical circuit is +12 volts anytime the ignition switch is in the run position. The other side of the electrical circuit is the ground path and is controlled by the computer. The computer switches the ground on and off to control the regulator solenoid.
EGR test procedure courtesy of cjones
to check the EGR valve:
bring the engine to normal temp.
connect a vacuum pump to the EGR Valve or see the EGR test jig drawing below. Connnect the test jig or to directly to manifold vacuum.
Do not connect the EGR test jig to the EVR (Electronic Vacuum Regulator).
apply 5in vacuum to the valve. Using the test jig, use your finger to vary the vacuum
if engine stumbled or died then EGR Valve and passage(there is a passageway through the heads and intake) are good.
if engine did NOT stumble or die then either the EGR Valve is bad and/or the passage is blocked.
if engine stumbled, connect EGR test jig to the hose coming off of the EGR Valve.
Use your finger to cap the open port on the vacuum tee.
snap throttle to 2500 RPM (remember snap the throttle don't hold it there).
did the vacuum gauge show about 2-5 in vacuum?
if not the EVR has failed
EGR test jig
attachment.php
To test the computer and wiring to the computer, you can use a test light across the EVR wiring connectors and dump the codes. When you dump the codes, the computer does a self test that toggles every relay/actuator/solenoid on and off. When this happens, the test light will flicker. If the test light remains on the computer or the wiring is suspect.
To check the EVR to computer wiring, disconnect the EVR connector and connect one end of the Ohmmeter to the dark green wire EVR wiring. Remove the passenger side kick panel and use a 10 MM socket to remove the computer connector from the computer. Set the Ohmmeter to high range and connect the other ohmmeter lead to ground. You should see an infinite open circuit indication or a reading greater than 1 Meg Ohm. If you see less than 200 Ohms, the dark green wire has shorted to ground somewhere.
Late Model Restoration may still have the Ford Racing M-12071-N302 kit with the EGR valve & sensor along with the ACT & ECT sensors for $45.
See http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=M12071N302 1&comp=LRS for more details
Yeah I came in after working on it, looked at the vacuum diagram and it occurred to me that I shouldn't have bypassed the EVR module. Unfortunately I only am getting about 30-45 minutes a day to mess with it before work.
So I should be able to plumb the manifold vacuum straight into the EVR valve, then into the EGR valve, and everything should be kosher (assuming the EGR is functioning correctly).
IT'S FIXED!!! Got up, and went to the parts store to rent a FP tester, came back home, hooked up the EGR valve through the EVR, hit the MAF with some brake cleaner, and it fired up and idled like my Cobra. It has never run this smooth before, especially stone cold like it was. I need to reset the idle cause it is idling at about 850rpms, but other then that it is like a totally different car. Thanks to all (esp jrichker) for the help!
