Here's where the best price is, not the one picture but they send the correct one: http://store.wpsracing.com/shiffor19mus.htmlSo, I'm assuming everything is installed from the top?
Gimme a synopsis of what's involved when you can.
Also, you didn't mention where you picked up the goodies at![]()
this is the brief version
- you need to remove the shifter bezel and console via the rubber bolts and screws under the hatch.
- disconnect shifter cable from UNDER the car, for me this meant moving my exhaust a bit. to get a wrench in there.
- disconnect the interlock cable from the shifter.
- disconnect all the electrical cables to shifter, this means i need to move out my speedcal untill i install the hot lead on the new shifter.
- Remove stock shifter bolts and shifter.
- install new shifter onto new foam gasket, put knob on in order to adjust later.
- Losen shifter cable adjuster nut as far as you can, move shifter back as far as it will go, then forward three clicks (Neutral).
- Conect cable to rear side of braket using provided self tapping screws. (99+s need the supplied adapter and spacer for this).
- Tighten adjusting nut.
- Losen front adjuster w/ tranny and shifter in neutral, then pull forward a bit to pick up slack and tighten.
- Turn ignition over one click and put shifter into park then install the interlock cable back on.
- now you make sure it's locked out from moving while in park w/out key and you begin to rewire the shifter + the LED light and o/d.
- reinstall console and bezel
And yea +100 on your car sounding amazing....thats how a stang is supposed to sound
