my car caught on fire NEED HELP FAST!
DarkoStoj
929
Detroit
I was planning on heading home from school today (1.5 hour trip) and am already running late. I get to my car and open it up only to realise the inside caught on fire!
Now I have no idea how this happened, and am atleast grateful that the damage was minor...but this just freaks me out about further issues with the car.
I need to know what the wires are that caught on fire, because I have to leave in the next 1/2 hour here and want to know what they are for.
Have you checked, does the car start?
I think the wires that run thru that area are the ones for the door switch (courtesy lights) and then the harness running to the back for your tail lights. Someone else could correct me.
I had a wire start to burn like that coming from my ignition. A short in my switch started it and before I couold get the battery disconnected (I was there at the time, thank goodness) it traveled thru the harness almost back to the battery melting all the wires it was next to in the harness. Take care in fixing it and make sure the short didn't travel into unexpected places.
Give your car a "pre inspection" inspection and make sure all the lights work. Cut and wire nut the exposed wires so they dont arc. If you are still driving it home, bring a fire extinguisher and a cell phone.
krash kendall said:
Those wires don't look like they started the fire (from the pics at least). Did the fuse box possibly burn and the melted drippings start the fire at the floor?
Krash has a good point, your fuse box is directly above the damaged area. You at least need to pull the fuse box down and inspect it.
Tim
I know the wiring on my '66 all too well, yours looks similar. The big bundle of wires that are running in the body (you can see them through the cut out) are stock and feed the taillights and fuel gauge. The other ones look non-stock to me, as they don't run behind the metalwork from above the dash.
Can you tell us what the colours are?
so i checked it out and everything worked, and the wires that were melted seemed to come from the headlight dimmer switch
I disconnected some of the wires & trimmed the exposed metal and made the trip
I got it home and I cut out all the damaged wire and replaced it. Seems to be working fine now.
