  • 1994 - 1995 Specific Tech
MY CLUTCH?????
  • Thread starter Thread starter 95stallion
  • Start date Start date Mar 5, 2007
9
95stallion
  • Mar 5, 2007
ok. when i drive my 95 gt it runs fine, but when i push the clutch in you will hear a little whine or whistle noise and when you let off of the clutch, theres no sound. yesterday i was at a stop light and had my foot on the clutch then i felt the clutch pedal go in even farther. when i took off i heard a weird sound so i pulled into a parking lot. when i turned off my car i smelt a burning smell and when i went to turn on the car there was a really LOUD squicking/whining noise. it will go in gear fine but if you try to move it, you have to have the rpm's high and let off the clutch for it to move and when you let off the gas and the rpm's go down it dies or wants to die unless you rev it. i have the money to fix it whatever it is but i just want to know if anone has had or know anyone that had this prob??
also if it is the clutch. should i buy this kit from jegs....
includes:
Ford Racing Cast Iron Flywheel
Ford Racing ''King Cobra'' Clutch, Pressure Plate, and Throw-Out Bearing
Clutch Cable and Quadrant
Clutch Fork
Pilot Bushing
Pressure Plate Bolts and Dowels
4 Quarts of Redline MT-90
555-60100K 5.0L Complete Clutch Kit -$438.99
OR
this kit from summit....
includes:
Brand: Ford Racing Performance Parts
Product Line: Ford Racing Clutch Kits
Input Spline Quantity: 10
Input Shaft Diameter (in): 1.062 in.
Disc Diameter (in): 10.500 in.
Disc Diameter (mm): 267mm
Disc Material: Organic
Disc Style: Sprung hub
Pressure Plate Style: Diaphragm
Throwout Bearing Included: Yes
Throwout Bearing Style: Standard
Alignment Tool Included: No
Pilot Bushing Included: No
Flywheel Included: No
Counterweight Assist: No
Mounting Hardware Included: No
Quantity: Sold as a kit.
Notes: This is the King Cobra kit.
Clutch Kit, Organic, 1 1/16 in. Diameter Shaft, 10-Spline, 10.5 in. Diameter Disc, Ford, Mustang, $184.95
thank you for your time and input!!!
bill302
2,131
alabama,gadsden
Mar 6, 2007
  • Mar 6, 2007
sounds like the throw out bearing went out..
HISSIN50
34
129
Mar 6, 2007
  • Mar 6, 2007
I like the way Sir William thinks. There also could have been some sort of diaphram finger failure in the mix.
FWIW, resurfacing the flywheel is often sufficient. Or a new one is about 100 beans. The KC kit would work well and 3 quarts of your favorite synthetic fluid are probably 30 bucks or less at the local speed shop.
Good luck.
Adam95GT
2,564
Burlington, NJ
Mar 6, 2007
  • Mar 6, 2007
Yea sounds like a TOB to me.... get that fixxed b4 you end up like mine with melted ballbearings and all... lol... i have the non king cobra clutch the plain FMS one works fine for me... aparently the cobra is a little more harsh but what ever... the one from summit looks good... but you might wawnna pick up a pilot bearing for like $8 while your in there and check your rear main seal.... just foods for though... just take the flywheel to get resurfaced for like $44
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
