My current problem
sliepnir16
26
So lately my 91 has been running like crap. I was coming home one day and at a stop light I felt the car start to idle a bit rough. The light turned green and I took off but with some hesitation and an engine severely cutting out, but finally I put my foot into it and the motor eventually caught and took off. I then noticed that if I cruised, the motor would cut out so I had to keep the rpms up above 2500. As the trip continued it got worse. It eventually gave out on me around some 90 degree turns where I couldn't keep the rpms up, I tried to pump the throttle but It wouldn't do anything. When I was stranded, I checked the filter, the pressure(not with a guage, but it had pressure) and spark I checked when I got home, all is fine. On the way home it died 3 or 4 more times, each time I had to wait about 10 minutes before it would start and move again, I then had to keep the rpms above 2500 or else I wouldn't go far. Ive taken it to a mechanic who says they can't do anything since the engine is not original and the vin numbers wont match the motor when they insert it into their computer. Nevertheless, they said its getting good spark and it holds 35 psi of fuel pressure at all times. Most days it will start upand idle fine, other days it will not. It has not ran as bad as it did that one day for some reason, now it cuts out but wont ever shut off while driving it. They also swapped out a coil to see if that was it, no changes. When I pull the codes I get:
KOEO- 15-85-15-85 pulse 11-11
KOER- 42-33-42-33
Cylinder Balance-90-90
I know 42 is o2 sensor, but I don't think that can cause something this severe. My EGR does not have a vacumm going to it so that triggers 33. There is no smog system, generating the code 85. Code 15 seems to be the possible problem, which is a computer permanent memory test failure.But they say everything in the car will go out before the eec, I really don't know what to do, thats the only thing in the codes that can cause symptoms that bad. The car does not have a computer chip, and I did clear the codes to try to clear that one as well. Besides having a performance chip, what could trigger code 15 so I can make sure it's not the eec. Ive tried the voltmeter test with it but there is no way for me to identify the #1 prong in the eec.
Any pointers would be appreciated.
There seems to be oil or carbon coming out of all of my spacers or gaskets Except valve cover gaskets etc. Ive already checked for vaccum leaks as well. So id say it could be a possibility, would that also signify a bad PCV valve?
