  • SN95 4.6L Mustang Tech
My friends new PI trqe converter!
  • Thread starter Thread starter big T
  • Start date Start date Oct 22, 2005
  • 3
First Prev 3 of 3
foncarelli
156
Oct 26, 2005
#41
  • Oct 26, 2005
  • #41
My converter has been holding up fine. The only regrets i have is that i wish i wouldnt of installed gears and the shift, kit all at the same time. I can't really tell the effects that the converter had by itself. :Track:
ProCharger GT
153
Cleveland
Oct 26, 2005
#42
  • Oct 26, 2005
  • #42
yea but it would have been dumb to do everything separate unless you got the $ to burn
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Oct 27, 2005
#43
  • Oct 27, 2005
  • #43
propellerhead said:
Single disc converters can't be that bad. All the stock ones are single disc, and there are thousands of those running at the track all the time. Check out other message boards sometime. There are many track only high horsepower cars that are running single disc converters. It's probably like axles. Some break at 250 rwhp. Some last forever with way more horsepower than that.
Well, I managed to blow the single disk converter in my car. Many others have as well. If you check the other message boards as you suggested, you'll see others have done the same. As for people running the stock torque converter, you must remember the stock torque converter doesn't have as high of a stall speed as these aftermarket converters, therefore, they don't have to lock up at higher rpm levels after launch, like you do with aftermarket converters. Two, the stock torque converter is 11in in diameter, which means it has a clutch plate that is equal sized to match. Because of that extra size, it has a bit more strength.
I'm not saying you might not manage to get by with a single disk converter, however, from what I've seen, I wouldn't trust one.
propellerhead
1,541
"but what's with the but shots?"
Oct 27, 2005
#44
  • Oct 27, 2005
  • #44
Excellent point.
What brand/model was the single disc that you blew? What horsepower level did you have?
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Oct 27, 2005
#45
  • Oct 27, 2005
  • #45
Propellerhead, I have a Precision Industries single disk lock up torque converter. I don't know exactly how much power I'm making, but I have pretty much every bolt on under the sun. The torque converter still seems to function "ok" for daily driving, but definately slips, especially after the 1-2 shift. It just can't seem to lock it up as it should. I've already talked to dirtyd0g, and it will probably be around 400 dollars to converter my PI single disk to a multi-disk setup. I wish I had purchased a multi-disk torque converter to begin with, because this could have been avoided.
Basically put, it takes a wise man to learn from his own mistakes, but an even wiser man to learn from the mistakes of others. I guess it's up to you if you want to be "wise" one day, or be wiser now.
propellerhead
1,541
Oct 27, 2005
#46
  • Oct 27, 2005
  • #46
How do you know it's slipping?
ProCharger GT
153
Cleveland
Oct 27, 2005
#47
  • Oct 27, 2005
  • #47
PI triple
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Oct 27, 2005
#48
  • Oct 27, 2005
  • #48
It doesn't slip all the time per say, but I know it's slipping by the "signs" of a slipping torque converter clutch.
1. When I'm driving around town, with steady throttle pressure, the rpms will drop when it shifts into 3rd gear, but then suddenly jumps for a few seconds and then shifts into gear. Again, this is with steady throttle pressure, and no SES light, no intake or exhuast leaks....nothing. It has to be the torque converter clutch, at least this is my only guess. I'm planning on getting a guy I know hook a scan tool up to it, and see what happens on the road test. He can read if its slipping.
2. When I romp it, and the car goes from 1-2 gear, I notice the pull through second gear is lacking in pull and power. I'm not saying this alone concludes that it's the converter, but I know my car well enough to know when it's not producing all of its power, or getting it all to the wheels.
T
TGJ
1,049
#49
  • Oct 27, 2005
  • #49
One of the best ways to tell if your TC is slipping is to hook up a trans temp guage. Sudden increases in temp is a sure sign of a slipping TC.
propellerhead
1,541
Oct 27, 2005
#50
  • Oct 27, 2005
  • #50
I see. I've watched a couple of parameters using the Predator. They are based on the flywheel vs driveshaft rotation speeds. I thought you were doing something like that.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Oct 27, 2005
#51
  • Oct 27, 2005
  • #51
Well, the only real way to know for sure is to do a diagnostic scan, and check the parameters for the torque converter clutch. However, all the other signs are there, so combine that with the fact that many people have had single disk converters failing, it seems like the converter clutch is the culprate.
propellerhead
1,541
Oct 27, 2005
#52
  • Oct 27, 2005
  • #52
I watch the Torq Conv Mod Commanded (TCCMCMD) and Torq Conv Mode Actual (TCCMACT). The Commanded drops from 1024 to 0 when it locks up. The Actual fluctuates around 1000 until it goes into lock up. Then it just fluctuates between 0 and 5. I guess there is a small amount of slip in the stock converter.
  • 3
First Prev 3 of 3
P
4 Hole Bosch Injectors max HP and Tune -4.6 PI
  • Png1978
  • Jul 23, 2022
3K
SN95 4.6L Mustang Tech Aug 10, 2022
Chipss36
Fresh Nitrous Tune
  • White Wolf
  • Jul 3, 2020
  • 2005 - 2014 Specific V6 Tech
2K
2005 - 2014 Specific V6 Tech Jul 4, 2020
White Wolf
K
New to me 1966 convertible
  • kimrpaige
  • Feb 28, 2019
1965 - 1973 Classic Mustangs -General/Talk- Mar 6, 2019
2Blue2
A
Advice for upcoming supercharged New Edge build
  • alwayshi
  • Jun 23, 2019
14K
1996 - 2004 SN95 Mustang -General/Talk- Oct 20, 2019
Dark04GT
R
  • Locked
SOLD 1996 Mustang Gt Convertible Pi Swapped
  • RedFord96
  • Mar 2, 2016
2K
SN95 Mustangs For Sale (1994-04) Mar 2, 2016
RedFord96
R
