there is only one to worry about correct? this might be easier to do, but if i got to sit there and grind out all those column things about 8 in each valve cover....im just gonna double stack with RTV like suggested..
remove the intake and valve cover and everthing else just to retorque them.......
....... i removed the baffle for the side that has the filler tube, all i did was remove the screws..... but i noticed that will allow oil to squirt up into the hose that goes to the tb....
idont want that, can i just cut the baffle so it flat or am i suppose to grind even more off the valve covers???
thanks for the reply but i think i got my valve covers squared......
im more worried about where to find the dill and tap for a act into my exploder intake..... and also the egr coolant flow needs to be tapped and i dont know the sizes and i cant find a drill and tap for these things anywhere.. home depot and tractor supply dont got them,,,
