My huge headache
hotrod coupe
Hello out there in mustang land! I have a problem that I cant find any info on....I have A 1986 4cyl s-rod fourspeed coupe shell(whole car minus ANY wiring, none. not even the headlight harness anymore)and I also have a 94GT auto that is narrowed at the driver door by a tree. the GT still runs but I want to change EVERYTHING over to the fox, can I just park them next to each other and go to town or is this more than it is worth. this is my third coupe and my first GT but Ive never dug this far in. The coupe is carbed but I want the fuel injection too. PLEASE HELP ME!!!!!
While most of the parts will transfer, some will definitely not without some modification. I'd say if you have a lot of time and a good place to do it, dive in and just start doing it. When you run into problems, just get on here and ask. Right now its too broad to give you any real good advice without filling pages and pages of this thread. Keep in mind this is a solid long-term type of project.
The first thing I'll tell you is that you're going to want to use as much of the '94's suspension and drive train that you can, but you will probably need to pick up some Fox-specific parts. The good news is that you can use the suspension parts from the '94 on the fox and have a 5 lug car!
Lastly, you should start a project/progress thread, because we all enjoy seeing that. :nice:
Good luck!
Most of the parts are transferable. Personally I would ditch the upper intake and TB setup for the fox style pieces. You may also want to consider switching in the sn95 dash like another member here did.
IMO, this is more trouble than it's worth.
You would be far better off with another wrecked fox as a donor.
Using the dash is cool, but it's far from a slap it together quickly project.
You could probably swap over a fox to a fox in a matter of days with some hard work, making all the 95/95 work properly isn't going to go so easily, especially since you are missing all the wiring.
The 94 accessory setup sucks too, dont know if you can use it, but even if you could, i wouldn't. Which means you now need a foxbody donor engine to get the accessories and brackets off of.
Like 2000 says...the accessory set up is lame...parts are different an more expensive since they only made that set up for the 94 an 95 models. I'd think the easiest thing to do would be to use the motor/trans, brakes, seats. Find a stripped fox for the dash stuff an headlight wiring. Then go with a a carb intake set up to save all that headache of the computer stuff. I went with a carb set up to save time an money...If i want EFI later on I might add it or get a stand alone system.
Everything will not be a bolt in install but it can be done. As said earlier the SN95 brakes are much better than the fox stuff. The engine is a direct swap but the bellhousing and tranny are slightly different but can be made to work. The front cover and water pump are also different.
I agree that the 94-95 acc setup is a bit of a pain but mainly due to a lack of aftermarket parts and valve cover clearance (the altenator will hit most aftermarket valve covers). These parts can be sold to finance the fox stuff if you want. Keep the Alt. though it's better than the fox style and is easy to adapt.
