My ignition tumbler is stuck!! Someone please help!
  • Thread starter Thread starter tylerdred
  • Start date Start date Jul 22, 2007
T
tylerdred
75
Chicago, IL
Jul 22, 2007
  • Jul 22, 2007
Guys, I feel like a complete idiot and have the stupidest question....
I try to start my car (1989 Mustang 5.0), and the key wont turn at all. I guess when I turned the car off, the steering wheel was rotated 180 degrees. So now, when I try to start the car, the tumbler wont move forward or backwards to turn on the ignition. What could I be doing wrong? Has this happened to anyone else?
Hickfied
413
Morganton, NC
Jul 22, 2007
  • Jul 22, 2007
It's happened to me, I just had to pull VERY hard on the wheel. Another time I had to jack up the front end to get anymore trave out of the wheel because of the resistance on the surface I was parked on.
T
tylerdred
75
Chicago, IL
Jul 22, 2007
  • Jul 22, 2007
I sprayed the tumbler with WD-40, turned the steering wheel as hard as I could, still nothing
HISSIN50
34
129
Jul 22, 2007
  • Jul 22, 2007
Turn the steering wheel in the opposite direction of which it was turned to lock the column. Now while holding the wheel, turn the key. This will remove resistance and let the key rotate.
Hickfied
413
Morganton, NC
Jul 22, 2007
  • Jul 22, 2007
Guess I left the part out about turning the key while turning the wheel lol.
HISSIN50
34
129
Jul 22, 2007
  • Jul 22, 2007
Nah, I knew what you meant.
I figured it best to be very explicit since pulling on the wheel could be interpreted several ways.
T
tylerdred
75
Chicago, IL
Jul 22, 2007
  • Jul 22, 2007
still no luck...what to do next? could a locksmith out of the yellow pages fix this? or would i have to tow it to a ford dealership (really dont want to do this)......
HISSIN50
34
129
Jul 22, 2007
  • Jul 22, 2007
If wiggling the wheel and key didnt help:
Are you sure it's not an issue with the key inserting properly into the lock? On some cars you have to jiggle the key or back it out a little bit for it to turn.
If none of that works, there's a chance the linkage broke and is bound up.
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
  • brandyn200
  • Jun 20, 2026
AeroCoupe
H
Engine 1992 mustang LX starting issue
  • Hdbandit
  • May 25, 2025
Fox 5.0 Mustang Tech May 25, 2025
General karthief
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
4K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
