well thats just it. the first set of numbers were pretty much without a tune after adding the l/t. the second set is after tuning for the l/t. l/t's are a mod that should be tuned after. ofcourse the tune gives it some power. that is the case with all mods. if the a/f is not corrected you are not gaining the full power. you can see the difference. peak was almost the same, but the tune fixed the numbers the way they should be, making the l/t much more torquey.
the car stock has the correct a/f so after a mod you should correct a/f and that is the power made by adding the mod.
