  • 1994 - 1995 Specific Tech
My mustang hates me!
  • Thread starter Thread starter jmellinger2063
  • Start date Start date Feb 25, 2009
J
jmellinger2063
Shafter
Feb 25, 2009
  • Feb 25, 2009
<a href="http://s250.photobucket.com/albums/gg242/jmellinger/?action=view&current=DSCN1206-1.jpg" target="_blank"><img src="http://i250.photobucket.com/albums/gg242/jmellinger/DSCN1206-1.jpg" border="0" alt="Photobucket"></a>
<a href="http://s250.photobucket.com/albums/gg242/jmellinger/?action=view&current=DSCN1207-1.jpg" target="_blank"><img src="http://i250.photobucket.com/albums/gg242/jmellinger/DSCN1207-1.jpg" border="0" alt="Photobucket"></a><a href="http://s250.photobucket.com/albums/gg242/jmellinger/?action=view&current=DSCN1208-1.jpg" target="_blank"><img src="http://i250.photobucket.com/albums/gg242/jmellinger/DSCN1208-1.jpg" border="0" alt="Photobucket"></a>
This hose broke and I have no idea what it is???
any and all help would be awesome!!!:SNSign:
99FiveOh
2,051
20
99
J-Ville, FL
Feb 25, 2009
  • Feb 25, 2009
That hose controls all your vacuum actuated gizmos under the dash, such as your vent direction. I'll bet with that disconnected, your air only comes out of the defrost doesn't it?
Adam95GT
2,564
Burlington, NJ
Feb 25, 2009
  • Feb 25, 2009
Thats what im thinking as well
J
jmellinger2063
Shafter
Feb 25, 2009
  • Feb 25, 2009
I'm not sure, but my car is shaky and wants to die when its disconnected .
The O.G.
145
witch city,mass
Feb 25, 2009
  • Feb 25, 2009
put a new hose on
vacuum leaks and efi =
M
madams74
664
Maryville, TN
Feb 25, 2009
  • Feb 25, 2009
The car comes with a connector at this joint. It is part of the climate control system. You will have a problem with the idle when you unplug this because your leaking now. You can get a rubber coupling that will allow you to connect the 2 hose back together.
95Vert383AOD
1,133
34
69
New Bedford, MA
Feb 25, 2009
  • Feb 25, 2009
get a lil gasket maker and put it around each of the broken sides ***Don't cover the hole obviously*** then slip some 1/4 vacuum hose over each side to fix it. I know i said it before but don't get the gasket maker near the broken ends....blocking the vacuum wouldn't be good. This is how you fix any plastic line. Some folks just slide the 1/4 over these hard plastic lines....i don't like leaks so i use a lil gasket maker to ensure a proper seal.
Brake-hose-to-drum Fit Issue.
  • 70mstang
  • Mar 2, 2018
Classic Mustang Specific Tech Mar 2, 2018
70mstang
Diy 87-93 Mustang Instrument Cluster Led Upgrade And Triple Guage Pod Install
  • stang89bidges
  • Nov 30, 2015
20K
Fox 5.0 Mustang Tech Aug 11, 2024
Mindseye007
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
  • Locked
Expired Stock 75 amp alternator
  • mikestang63
  • Nov 17, 2012
  • Engine and Power Adder
Engine and Power Adder Nov 17, 2012
mikestang63
C
Engine why is this oil leak happening? (pic)
  • craig3x
  • Feb 2, 2013
2K
Classic Mustang Specific Tech Feb 28, 2013
SHEDRED
