My new Fox
  • Thread starter Thread starter rangerboy101
  • Start date Start date Oct 11, 2011
1 of 2 Next Last
rangerboy101
310
20
28
Inwood, WV
Oct 11, 2011
  • Oct 11, 2011
My parents picked up an '88 a few months back for me. I haven't even gotten to see it yet because of other projects I have going on. Here's a list of everything that's been done to it:
Lowered
saleen wing
308
10:1 compression
Trick flow stage 3 cam
Ported and polished gt 40 heads and upper and lower intake
24 lb injectors with matching maf sensor
Cold air intake
Taylor made 10.4mm wires
Msd 6a ignition box
Flex fan
No ac
Offroad h pipe with flowmaster 40 series
Bbk equal length headers
Short throw shifter
Adjustable clutch cable
King cobra clutch
3:73 gears in rear
Sub frame connectors
Rear sway bar
5"monster tach
And oil pressure guage, temp guage and amp guage in center of councel
New radiator
New speed sensor
New fuel pump
New fuel guage
New fuel pressure regulator
New spark plugs
New battery
Problems:
speedometer doesnt work but i do have the cable to fix it and will go with the car
doors do not lock
primed in color
That was just copied from the CL ad. You guys see anything particularly wrong with what's been done? I'd say the Stage 3 Cam is a bit much but like I said, I haven't even seen it yet. I'll be sure to post some pictures when I bring her home. In the meantime, here's the only ones I do have of it:
rangerboy101
310
20
28
Inwood, WV
Oct 11, 2011
  • Oct 11, 2011
Also, a couple people I've talked to said I should run Premium in it because of the 10:1 compression. What do you guys think?
LarsD
2,680
119
123
Texas
Oct 11, 2011
  • Oct 11, 2011
Definitely run premium in it. Ditch the flex fan for a Taurus fan or clutch fan. Those flexies are dangerous. Looks like a good canvas, welcome!
5.0Torx
252
Oct 11, 2011
  • Oct 11, 2011
If this is your first fox, welcome aboard!
That being said, I would say you're buying someone elses project, so beware. Hopefully the previous owner / owners for this car hasnt totally run this thing into the ground. When I bought my '93 LX, the P.O. made no mention of the fact that it was actually the front half of one fox welded to the back half of another. Cheers!
And yes, run premium fuel because of the compression ratio and, more than likely, highly advanced timing.
rangerboy101
310
20
28
Inwood, WV
Oct 11, 2011
  • Oct 11, 2011
Yea I planned on that. I have a Taurus fan in my garage that was going to go into my Ranger but I think this needs it more haha
Thanks. Yea I'm going to have to go over it really well to see what all has been done. Im not a fan of finishing other people's projects but I got a decent deal on this thing.
rangerboy101
310
20
28
Inwood, WV
Oct 22, 2011
  • Oct 22, 2011
Little bit of an update:
I've been working on fixing all of the little problems. I've fixed most of the little electrical issues. All the lights work now, signals work, hazards work, and the only thing left is to get a bulb for the dome light and get the gauge cluster lights to work. Once I get a horn wired up, she'll be ready for inspection and be getting tagged.
LarsD
2,680
119
123
Texas
Oct 23, 2011
  • Oct 23, 2011
Looks good!
rangerboy101
310
20
28
Inwood, WV
Oct 23, 2011
  • Oct 23, 2011
Thanks man. I need to get some new suspension under her soon though. I found out they cut the factory springs up front to lower it :/
D
danond
36
  • Oct 23, 2011
Not a good sign. Stay on the lookout for other corner-cutting mods!
Have fun. Foxes are like legos for big kids.
Dan in ND
rangerboy101
310
20
28
Inwood, WV
Oct 23, 2011
#10
  • Oct 23, 2011
  • #10
Dan in ND
I've gone over the whole car and that's the only thing I could find.
Boosted92LX
5,721
4,244
224
Oct 23, 2011
#11
  • Oct 23, 2011
  • #11
Nice starting point. I'm blind, but to me the gray looks like primer. Any plans yet on a paint color?
Oh, and hit me up if you wanna part with that intake later on.
jdwyer25
116
Cameron, NC
Oct 23, 2011
#12
  • Oct 23, 2011
  • #12
Looks like a solid project.
stang&2Birds
2,091
New England. :-) CT/MA
Oct 23, 2011
#13
  • Oct 23, 2011
  • #13
Nice find!
What State are you in, and do you plan/need to drive it during the winter?
IMHO, a few things:
o ALL 5.0's must use premium gas. Don't even think of being foolish and trying something else. The 5.0 does not have a knock sensor. So, lower octane gas can mean big problems.
o Cutting the stock spring is no worse than using the "B" springs. And, in fact, it's better because it increases the spring rate a little. The POS B springs lower the car and are too soft and too low. Lowering a Fox is fine for looks, but lowering a Fox more than ~3/4" hurts handling a lot. Also, Qtr mile times are worse.
So, it depends on why you want the car lowered. It's your car, not mine, not some other person's on the forum. Lower the car for the reason you want, not what other want.
FWIW, for better handling, you have to go up to at least a 600 lbs/in spring.
o The flex fan is scary. That shows that who ever did the mods didn't have a clue about performance. The stock thermal clutch fan is MUCH MUCH better than any flex fan. In fact, other than an electric fan setup, the stock thermal clutch setup is the best you can have.
If you drive the car in the snow, then you'll need real snow tires. Get them mounted on separate rims. Rims for the 5.0 are dirt cheap.
For wiring diagrams, TMOSS did a lot a nice diagrams. They are at:
Mustang FAQ - Wiring & Engine Info
Good Luck!
LarsD
2,680
119
123
Texas
Oct 23, 2011
#14
  • Oct 23, 2011
  • #14
I have one on my shelf I'm not using.
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,241
2,949
224
Vass, NC
Oct 23, 2011
#15
  • Oct 23, 2011
  • #15
very false.
Aside from that, great post!
rangerboy101
310
20
28
Inwood, WV
Oct 23, 2011
#16
  • Oct 23, 2011
  • #16
The car is prime red. I plan on ditching the GT bumper and Saleen wing and getting LX stuff. Also want to get a new hood as this one has been cut up for hood pins. In spring I'd like to paint it black.
Thanks
stang&2Birds said:
Nice find!
IMHO, a few things:
Good Luck!
I'm in Winchester, Va. The car will not be driven in snow but I will run it every now and then during the colder months just for the hell of it. and I want to change the springs because the car sits way too lowcas it is now. I'm tucking about 1/2" on 245/50's right now and it scrapes the pipes pretty bad on certain roads in my area. I bought the car basically for a toy. I wanted something that I could drive everyday if needed. I've got a Ranger as my DD.
Flossy
98
Chico, Ca/ Misawa, Japan
Oct 23, 2011
#17
  • Oct 23, 2011
  • #17
Ill buy the Saleen wing off you if it is in good condition.
rangerboy101
310
20
28
Inwood, WV
Oct 23, 2011
#18
  • Oct 23, 2011
  • #18
It has a chip/small cracks on the left hand side. Other than that, it's in decent shape. Just needs a decent coat of paint.
RAYZEN CAINE
51
#19
  • Oct 23, 2011
  • #19
Thanks
I'm near Winchester and if your looking for a LX wing I have one in perfect condition for $30 and a stock hood for $20. If you're interested just shoot me a PM.
rangerboy101
310
20
28
Inwood, WV
Oct 23, 2011
#20
  • Oct 23, 2011
  • #20
Consider them sold man.
1 of 2 Next Last
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
Engine 1988 Ford Mustang throwing 2 OBD-1 codes (32 and 63) rough cold start and initial idle
  • mikeah
  • Nov 16, 2026
Fox 5.0 Mustang Tech Nov 17, 2026
mikeah
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
