my new Pro-50 is a noisy little bastard
  • Thread starter Thread starter greenstang1313
  • Start date Start date Jan 29, 2006
G
greenstang1313
158
Chelmsford, MA
Jan 29, 2006
  • Jan 29, 2006
I just installed a pro50 shifter in my 94 Cobra about a week ago and the thing is so damn noisy!! I mean, I like the feel of the short throw shifter but It vibrates like mother ****er and makes the most annoying whining sound I've ever heard. I'm thinking about putting the stock shifter back in because I can't stand the whining and vibrating sounds it makes.
Is there anything I can do to get rid of the sounds?
(and btw I sealed it with the RTV gasket sealer stuff and that didn't help)
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Jan 29, 2006
  • Jan 29, 2006
You'll get used to it eventually.
D
Daggar
3,902
  • Jan 29, 2006
Did you install a gasket between the shifter and the tranny? One that looks just like the stock one you had to scrape off after removing the stock shifter?
M
meangreen92lx
52
Milwaukee, Wisconsin
Jan 29, 2006
  • Jan 29, 2006
I think it depends on the car. I put one in my 1992 with a newer t5-z trans and it is silent until like 4th gear at full throttle at higher rpm's, then it starts to rattle.
Put one in my buddys 1998 Cobra, and it sounds like a rock crusher all the time. Would drive me nuts.
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jan 29, 2006
  • Jan 29, 2006
Did you put the little rubber ball on the bottom tip of the shifter that goes into the tranny? That usually lowers vibrations and noise coming thru it.
2000xp8
SN Certified Technician
Aug 8, 2003
8,063
1,647
194
NJ
Jan 29, 2006
  • Jan 29, 2006
It really just magnifies vibrations that are already there. Over a period of time with my car, trans rebuilds, new flywheel, aluminum driveshaft, all took the sound from being loud and annoying to almost non existant.
speedingpenguin
90
MA
Jan 29, 2006
  • Jan 29, 2006
I'm greenstangs buddy, we didnt use one of those "shifter gaskets" you can buy now, but pleanty of RTV. My thought is that by using the stock shifter bushing with the pro 5.0 handle (using the stock bolts of course, so they would fit), that would reduce the sound a lot but still leave the shifter feeing pretty good....
Greenstang doesnt powershift or beat on the car at all so yeah the shifter might not feel as "precise" or whatever, but it would be quieter, correct?
8950HO
658
  • Jan 29, 2006
Are all these Pro 50 shifters noisy?My T-5 Tri-Ax shifter is quiet.
Did you set up the stop bolts properly?
Black1987Stang
1,422
Jersey Shore
Jan 29, 2006
  • Jan 29, 2006
Did you reuse the rubber dust shield that is right under the console and right above the shifter? That seems to knock down some noise. I also just used silicone on mine, I heard those rubber gaskets work good
Look Its Aaron
Your car looks like it came straight from Mexico.
2,634
Fontana, Cali
Jan 29, 2006
#10
  • Jan 29, 2006
  • #10
MGW > pro 5.0
8950HO
658
#11
  • Jan 29, 2006
  • #11
I reused the rubber dust boot from the factory shifter just to keep dirt out of the shifter mechanism.
I think the shifter companys should include a new dust boot with their shifters,but they are too cheap.I think Mac is the only shifter to come with a new dust boot if I`m not mistaken.
I would definately reuse the factory boot.When I removed my stock shifter the rubber boot was plastered in grease and grime.
NKau
1,346
Jefferson, WI
Jan 29, 2006
#12
  • Jan 29, 2006
  • #12
The Pro 50 in my old '89 LX used to rattle like mad at highway speeds or high rpm until I replaced the twisted driveshaft with an aluminum one. Same thing you're talking about basically; it's not the shifter so much as it is other imablances in the driveline that are causing the 'problem'.
90_Red_LX
668
Asheboro, NC
Jan 29, 2006
#13
  • Jan 29, 2006
  • #13
Myn is louder, rattles a bit, and whines but I'm so used to it now I don't think about it. I couldn't go back to the stock shifter. No way in hell.
95GTV8
386
Washington State
Jan 29, 2006
#14
  • Jan 29, 2006
  • #14
get an MGW, i didn't use a shifter gasket and it makes 0 noise. I just took a good ammount of time scraping all the old sealant material off of where the old shifter was, and then did the zig-zag RTV sealant pattern and put the new MGW piece on. I'd highly recomend the MGW as mine makes 0 noise.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jan 29, 2006
#15
  • Jan 29, 2006
  • #15
+1 for MGW nice quiet piece of equipment
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
J
  • JRC99
  • Apr 19, 2025
JRC99
J
