My PIR results
The Factor
1,485
beaverton,oregon
My PIR results...Just added some Video
Well I came close to nailing my 11 sec goal,but fell a little short.Best time tonight out of four runs was a 12.092 @113.42mph with a 1.774.. 60'... second best was a [email protected] with a 1.746..60',I missed 3rd gear on that one or I think I would of made it.The 12.092 felt good I thought for sure I nailed a 11 on that one.I think if I work on shifting a little faster and a little colder air I can do it.All in all though I improved my time so I guess I cant complain to much :shrug: but a 11 SEC run would be so sweet. :flag:If you go down to the seventh post theres some kool footage that Keith "Duner" took at the track.
Good job, you will get there soon!!
joe
03yellowvenom said:
:notnice: ya that 10:00 rule definately blows!!!!!!!! :D
magnaflow is quieter but some like the noise!!
Hey, on the boost bypass there is no need to change anything i will look at your program friday and set the parameters so it will not dump boost if that is a problem now. Are you going to make it to the track friday? let me know.
joe
WaterPog said:
What tires are you using now Ed? probably big DR's I'm guessing, with that kind of driving you could probably make a good run at the drag radial class on friday....
I guess 90 db is the loudest after 10pm and im at 94.3...but I just got some hi flow cats im hoping will do the trick.Suppose to only loose around 3 to 5 HP with them according to Bassani.,and thats around what I would loose with a quieter exhaust,so i'll try cats first,i like the sound now that i'm used to it ,but dont like getting kicked out after 10 at PIR. I have to work friday nights so its rare that i'll be able to make it.But I sure wish I could.I'm running nittos 555r's ,315-35-17's they hook up great.Thanks for the comp.Eric :nice: I can't wait to see you run :flag:
joe
Thanks Joe, No I can't go friday ,I'm working and I cant miss cause im missing wednsday to go to court for a traffic infraction :rolleyes:I read that im not getting all the boost with my pulley because theres a bipass valve that only allows around 9psi at wot...and if you just reverse the connections or get a bipass kit for like 16 bucks you'll get full boost :shrug: I should be going sat night to the track though,if its not to hot and the 24hr/sb :flag:
kck6894 said:
wow!!! I can't believe your that loud!!! I run long tubes, 3" O/R x-pipe, and magnaflo's with dumps. They checked me at 90.0 db. Good luck with the new cats
Thanks, ya the bassani x-pipe and borla stinger cat back really woke it up.Like my friends 7 year old said, my car sounds mad.....lol :D
Don't waste the 16 dollars i will solve the problem in the tune
joe
