My cars got a weird problem, it will run fine as long as im moving and driving, once I idle for over 10 seconds or so it will start running really rich? (exhaust has a smell to it anyway), it will lope like it has a huge cam in it, idles like crap period, has a really bad off idle stumple, vacuum drops down to 8 inches from a normal 12 inches, loss of power, and bucks pretty badly like a new driver driving a stick. It will stay in this "mode" pretty much as long as the engines running, but if I turn the car off and start it back up its GONE
and it will repeat again if i let it idle for 10+ seconds or so again. I have no codes, except for things that are deleted or I dont have (like VSS).....It never used to do this, all I can think of is the maf or the intake air temp sensor and since they both have to do with timing and the air/fuel ratio management....but then wouldnt they set off a code if they were that much out of range? btw the O2 sensors have less than 10k on them...... Im lost, please help me out
