My TFS H/C/I Progress Thread
Aliate X
602
Rockland NY
Well I figured this is needed because so many people ask so many questions about these TFS kits. As soon as this is all finished, there will be a dyno run with dyno video/sheet/numbers and before/after street videos.
Well lets start with how the motor looked before I started. Bone stock...even had the air silencer and dist. boot....I added the headers shortly after I bought the car (bbk ceramics).
Starting the tear down. Everything looked in really good shape minus one cylinder that had a few scores, but no big deal.
And here come the parts in the mail.....$2,642.68 for everything you see there. That is the TFS track heat kit in the black option with a FRPP water pump, TFS A/C Delete, ARP head stud kit (kit comes with ARP bolts) and FRPP lifters.
Other stuff I had to order :
TFS cylinder head dowels
2 extra TFS thermal plugs for the heads b/c Im running no emissions.
Throttle body still to come.
Heads, lifters, pushrods, and rockers all setup.
Lower intake on, along with 1 header, it seems that the new heads are larger so the driver side header will no longer go in without moving the steering linkage out of the way temporarily.
This Wednesday - Sunday, I hope to get the rest of the motor finished, I really ran into no problems with this kit except for dropping stuff into the oil pan lol. Thank god for a mechanics claw....
As soon as this is all together and the car is on the road the next weekend I will be heading down to Long Island (Mustang Magic) for a custom tune/flip chip. Im hoping to put down some real good numbers with this kit.
Ill keep this thread updated as progress follows.
Awesome, i really wish i had the money to do that seems like lots of fun, i cant wait to see the results. How hard are the heads to install?
Easy...the whole swap really isnt "hard" its just time consuming, like tomorrow Im going to take the timing cover back off because Im not 100% sure that I have locktite on the cam sprocket bolt. Actually bolting the heads on was probably the easiest part so far, you basically just put them on and follow the torque down procedure, thats about it.
The cam is probably the hardest part just because you have to be so careful, and if you mess something up your risking the entire motor.
Btw, I just opened the box with the filler neck in it, it has to be one of the cleanest looking filler necks I have ever seen, its going to look so sweet aganist the black, its just a very simple looking peice, the cap is just a circle of aluminum about 1/2 an inch thick with "TrickFlow" machined into it. I had FRPP valve covers a while back and they look retarded compared to these.
cool thanks man, just wondering because im going to be ordering afr 165's sometime at the end of the year, and I have a long time friend who buys and sells mustangs, hes built many motors, and can do anything, gears, etc. but hes just a home mechanic does all the stuff in his driveway so i wasent sure if i should trust him or just pay alot of money to have a machine shop instal it and measure everything etc.
Honestly, I know youve done work to your car and I would suggest doing it yourself, I feel so proud looking at the motor and it looks like something you see on TV or w/e and I know that I built it.
And its just nice to be able to say "I did the work" when someone asks.
sweet man, I have alot of time to think about it but id like to do it my self and maybe the guy can stand behind and watch me. Goodluck with everything and post the results when its done.
mob you will have no problem, i rebuilt mine stocker from the main bearings up with ease. I had my bro-inlaw there to make sure i didnt screw anything up, but these pushrods are as easy as it gets. and i agree the heads are the easiest thing to slap on.
AliateX, did you use the front and rear intake rail gaskets? or did ya just use RTV. it was a real biotch making sure they lined up fine, next time i thining of ditching them for RTV.
Aliate X said:
\As soon as this is all together and the car is on the road the next weekend I will be heading down to Long Island (Mustang Magic) for a custom tune/flip chip. Im hoping to put down some real good numbers with this kit.
Please, if you have 1/2 a brain you will listen to me and NOT take your car to mustang tragic! :notnice: :nonono:
Aside from the FACT that they suck, there is nothing on your car requiring a $600+ flip chip. I did 304hp/339tq with that combo stock eec tuned myself at the track. If you have to take it to a shop, take it to realspeed.
They set up my rear end and I cant say anything but good things about them. Its good to have the chip anyways for the future, its 600$ including the chip.
I just used RTV on the ends, it says in the directions not to use the gaskets anyways, but I cant figure out why they supply them..
Unfortunatly, you'll learn :(
I made the mistake of letting them tune my car and it was money wasted. I had to fix it all myself, which was what I shoulda done from the get go. $600 is a waste of money, I paid less than that for my PMS which can be used over and over with no hundreds of dollars for reburn fee's. I wish you luck b/c you WILL need it :nice:
Is there anyone else that can tune a h/c/i setup, I am under the impression that this car will not run right without a professional tune, I have an AFPR and I know how to set timing and such. Because if its not needed, than I can definitally use the 600 on something else.
Ok good I got you listening now :hail2:
I ran that combo on a 100% stock eec with very little issues. maybe a little surging here and there. If you're using a pro m meter you could try and find a used pro m optomizer which will tune the maf voltage and help with dialing in the idle. It also will do the same for WOT. Or you can buy a used PMS for $400 or so and tune it yourself.
Try it as is before buying anything. But do yourself a favor and don't let mustang tragic touch your car :nice:
How much trouble is the cam swap with the motor still in the car? I know it can be done, but is it a breeze or more of a pita. Looking at it w/ my car looks like the cam would have be started angled, but it also looks like it may open up a lot once you pull crap off. What else did you need besides what was in the kit?
