- Jul 12, 2006
- 684
- 24
- 19
So it's week 3 with this problem and I am running out of ideas with the exception of exploring into the engine.
To refresh your memory. What I have is a 96' GT that out of the blue started to miss. The miss is on all B2 cyls and there is no CK engine light for the miss BUT there is a rich B2 code (P0175). The car is down on power and at times idles like my 87' GT with an H/C/I.
I'm not usually the one to throw parts at a car to find the issue but rather step by step diagnose it BUT I am so stumped on this that I installed new coil packs, plugs, and wires and 2 brand new o2 sensors with NO change. It's like the more you mess with it, the worse it gets.
My wife's brother owns a auto repair shop and I brought the car to him and we went over it again. Smoked it for vac leaks. none. Looking at the computer with a scanner the PCM is trying to pull fuel away and the 02's are reading full rich. Even he can't find a solution or explanation.
Over this weekend I pulled the engine's main harness and omhed out every wire back the to PCM and I also ohmed out the O2's harness for both the front and rear O2's. I also checked compression one again with matching 160 on each cyl on that bank. I guess I could do a leak down, but since the compression numbers look good suggest no valve issues.
I guess at this point the only thing I could try is
1) a new PCM, though it's a pretty expensive item for not being 100% sure it's the problem here, but I don't think so.
2) Lash adjuster issue? Seems like I would heard some valve train noise?
3) Physically pull the front cover and verify cam timing though unless something with the guides failed and it jump a few teeth I can't see it being an issue.
4) Sell it and move on. I have seriously never had such a frustrating issue in all my life working on Ford's and my wife is starting to think I'm nuts.
Any extra help or ideas would be great.
