Can anyone tell me what this connector goes to in this picture, its the round one with the red top next to the air box.
My alternator itself turned out to be my drain. I rebuilt it and all is well again.
Ok guys, I need some more anwsers, I went and bought a new alternator today and also a new battery and put them both on the car, then when I started the car and put the voltage tester on the alternator I still got the same reading, about 11.50 So I took it to advanced auto and had them test the alternator and also brought my voltage meter with me to double check and it came up with about 14.50 when they had it on the machine. So my question is should I be reciving 14ish if the volt meter is right on the black and orange wire nut on the back on the alternator? or if something within the car was draining it would it read the 11.50ish? also want to know what the A S I on the back connector stands for, Ignition Signal and something else? also how is the alternator grounded out? I have painted my alternator bracket could that be making for a bad ground?
Thanks! :SNSign:
I have been searching a lot tonight and found a good amount of threads with some good info on them. But I also want to know why the alternator is just sending out 11.50 volts while running, right off the back of the alternator black/orange wire nut before the fuseible link? is that the voltage when the ignition wire is not working and telling the alternator to not charge? also my alternator light does not come on when the key is turned on, but I tested the bulb and it is still good, so do you think it could be the red/green wire? I got to test all these things tomorrow but just want a little more input so I know what to test first (besides the grounding) is there something else besides just wire between the alternator and the "AMP" light that would blow or break? and one last question what does the yellow/white and the short white wire do on the D harness?
Thanks!!!!
