  • SN95 4.6L Mustang Tech
Nasty valve train click (?)
  • Thread starter Thread starter alexrhodes
  • Start date Start date Nov 5, 2011
A
alexrhodes
  • Nov 5, 2011
I have a nasty valve cick. Tried to pull the valve cover, couldn't get it off all the way without disconnecting the AC lines. Couldn't see much the amount i got the cover open,The sound goes away at higher RPM. Heard it could be a plug blowout? never even thought to check t spark plugs. Going to do that tomorrow. I put this video up of the sound, you can hear it clearly but may not be of much help in diagnosis. Thanks in advance.
Nast valve click - YouTube
D
Deleted member 38176
Nov 5, 2011
  • Nov 5, 2011
That sounds a lot like my car just before I blew a plug. I'd definitely remove and retighten all plugs and see if the sound goes away.
trinity_gt
3,125
81
99
Canada
Nov 5, 2011
  • Nov 5, 2011
Looks like a 4V and thus it shouldn't be prone to the spark plug issue like some PI-headed 2Vs are. Checking the plugs is a good idea but I suspect you're going to find the issue is in the timing chain guide/tensioner area.
Silly question: Does the oil pressure gauge show the engine as having pressure?
A
alexrhodes
  • Nov 5, 2011
Yes, it shows oil pressure, and i read about the plug blow out issue, but all of the plugs are snug, and the car didn't run like it would if a plug blew out and it had a dead cylinder. I'm leaning toward a tensioner problem or something too, i was hoping maybe there was something common to 4v that causes that noise. thanks for the replys. any suggestions on what to try next?
D
Nov 5, 2011
  • Nov 5, 2011
I didn't even notice that
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
G
Resolved URGENT HELP!!
  • Gilroy gonzales
  • Mar 26, 2023
3K
SN95 4.6L Mustang Tech Jun 1, 2023
Gilroy gonzales
G
J
  • JRC99
  • Apr 19, 2025
JRC99
J
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
