Ne1 Try These?
Ive heard reviews on all girdles they just delay the inevitable. They are good for holing the block together when it does break so you dont loose all of your internals.
Well that's even more optimistic than what I've seen on them so far. The contact patch/point on the valley girdles isn't enough to stiffen up any portion of the block at all. From what I've gathered, it's a device that seems to serve no purpose other than holding the two halves together when you split the blok down the middle of the lifter valley.
I call squirell dung!!
So exactly what is that going to do that your intake won't do??? You could make your own, and have them welded into the valley instead, but if she's going to crack, she's going to crack, and maby not split, and maby it will save your internals.
