  • SN95 4.6L Mustang Tech
Need 2003 Cobra tank/pump combo
  • Thread starter Thread starter 2k1bullitt
  • Start date Start date May 17, 2004
2k1bullitt
  • May 17, 2004
The cheapest I've found so far is $485 for the pump and another $425 for the tank. Anyone have recommendations where I can find a lower price?
Thanks.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
May 17, 2004
  • May 17, 2004
Thanks.
www.modularfordpowerhouse.com , call tim
and post this in ford parts section of the forum at modulardepot.com
mogs01gt
3,113
30
119
Ohio
May 17, 2004
  • May 17, 2004
I have also heard that some guys are swapping the two cobra pumps out with two Focus pumps.
2k1bullitt
  • May 17, 2004
Steeda sells a dual 190 lph setup for $399. Think I'll go that route.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
May 17, 2004
  • May 17, 2004
steeda is good for about 400 rwhp but if you wanna do it once and not worry go with the cobra
M
mike4814
9
  • May 17, 2004
I got the steeda set up on my 02 GT and it works great! More then enough fuel and alot cheaper then switching to the cobra set up. My car put down 420 hp at the rear wheels on a mustang dyno and the pumps worked fine. If you do decide to go with the cobra set up you can switch the 2 cobra fuel pumps with 2 focus fuel pumps they flow better and provided alot more fuel either way god luck
2k1bullitt
  • May 17, 2004
Thanks for the input everyone!
scheister
612
Indy
May 17, 2004
  • May 17, 2004
I have the Cobra pump and tank setup....it has been proven past 660rwhp.... Talk to Tim at www.modularfordpowerhouse.com
Chad
Bullitt_#1346
767
Atlanta
May 17, 2004
  • May 17, 2004
You will waste money doing something other than the '03 Cobra setup. Eventually you will need it, and then you will have spent money on other setups for nothing.
I went through two or three different fuel pump setups before I got the '03 Cobra setup. Everything else was just a waste of money.
CBASS
853
Wichita, KS
May 17, 2004
#10
  • May 17, 2004
  • #10
Talk to Randy over at Modulardepot.com
http://forums.modulardepot.com/showthread.php?s=&threadid=23090
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
Fuel Damper, 2003 Mustang GT
  • bmmckl
  • Dec 19, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 19, 2025
bmmckl
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
