I am in need of a harmonic balancer 28 ounce stock for 302W
does napa carry them where do you get them from??
I got one a few years ago from martel bros (aftermarket) to replace a cracked one and now my timing just seems horibble off now
I pulled the timming cover and the chain is dead on marks line up beatiful but it appears the markings on the balancer either slipped or they were never in the right spot to begin with (aftermarket balancer)
cylinders have 150-160 psi
I did the Tdc check with a piston stop and it appeared the intake valve was opening right on schedule--3 btdc as per the cam card...
symptoms-- adjust timing so it runs and it pings
set it back down horrible take off can you say slug
fuel problem maybe edel 1406
ignition is MSD 6AL
I got some video with car running it post tommorow..
ignition is MSD 6AL
