Roadblock said:well i am considering making a hardtop from the frame of the soft top, if all goes well other interior parts maybe made too
I DiDio I said:
Michael,Michael Yount said:So I thought I might make a mold from the existing extrusion from which I can then pull a replica bumper out of fiberglass.
I'm curious about what types of glas to use (strips, weaves, fibers, etc.) and what resin. Also, I'm not certain a one piece mold is gonna do - the sides of the bumpers (wrap around) have a slight curve to them that I think will make it difficult to extract the fiberglass piece without stressing/breaking it. So I may need a two piece that I can unbolt/disconnect in the middle and slide the halves off of the finished piece. Kind of hard to describe without pics. Also, would love to have your thoughts about mold materials (plaster vs. fiberglass) and release agents.
i was considering trying something like that for my car too, but time and financing have not presented themselves yet ...Roadblock said:well i am considering making a hardtop from the frame of the soft top, if all goes well other interior parts maybe made too
It really depends on what the temperature is and how much hardener you use to deternine the set time. This is usually done by trial and error with small peices.Michael Yount said:The front bumper has to support an air dam which attaches to the bottom of the bumper. That dam sees pretty good aero load when cruising down the road at 70 or 80 mph. I may also want to cut some openings in the bumper and mount driving lights behind it. So I'm wondering about ways to reinforce the front bumper. Both can be pulled from the same mold. I've been thinking I could imbed some light gauge aluminum or steel strapping in the areas where holes will need need to be drilled to attach the air dam.
One thing I'm not clear on is how quickly does the resin set up once it's catalyzed. And, how many layers will it take -- I assume this is built up like lasagna - resin, imbed the cloth, saturate, more resin, more cloth, etc. How many passes does it take to come up with say 1/8" thick fiberglas?
Yes you can imbed the color in the glass. It can be done in 2 ways. The use of Gelcoat, like a boat would use for example, or you can buy pigment for the resin that will make it any color you desire.Michael Yount said:Oh - can you imbed color in the glass? I don't want a gloss finish - I'm happy to paint to the finish I desire. But due to the amount of rock-chippage the front bumper will see, it would be great if the base color of the resin were black - so as black paint is chipped, it's not as noticeable.
