If you had factory ministarter you won't need the wire kit - correct.
In fact, it's not really necessary with the big starter. Just swap the big cable from the switched-side of the fenderwell switch to the 'hot side', and then use a 10ga or 8ga wire from the switched side of the fenderwell switch to the small terminal on the starter. Voila - you're wired.
