Need a tune? Is this combo okay without?
ozanracing
172
The combo is: 306", Lunati custom 228*/232* @.050" W/ .501"/.513" Procomp 190cc heads, street heat intake, 30lbs injectors, fp@ 40-42psi, 70mm TB, 73mm
Vortech MAF with calibrated sample tube. longtubes. cr- ~9.2:1 16* timing.
Runs great, but I don't know if there are any lean points, think it'll be fine?
I'm going to be spraying a dry shot also, but for now I'm only concerned with NA.
I think it should be okay.
normally i would say to stay away from a dry shot but if you are going to be getting a custom tune than go for it. just make sure you use a window switch to keep it from spraying until the custom tune gives the engine enough fuel.
but as far as needing a tune i think you will be fine. that fuel pressure looks good enough to keep you from having any lean spots at all
Oh one more thing. I'm using a stock fuel pump...I have a new 190lph in the box in my shop just waiting for me to install it, but I was thinking: Know how injectors have a hp limit? like 19lbs are good up to 300rwhp or so? How about fuel pumps? At 6000rpm+ Is that stock pump being overworked and not providing adaquate fuel??
