need advice fast.
  • Thread starter Thread starter texasmustang316
  • Start date Start date Feb 28, 2010
T
texasmustang316
11
  • Feb 28, 2010
i have a 86 mustang that was a 6cyl. fuel inj. and i swaped it to a 302 carb. i bought a holley fuel reg with bypass from summit and a carb and it ran fine for a week. now it won't stop flooding the carb. i have adj. everything and still does it. my guess is the reg is defective. my question is i am running a holley in tank pump i am not sure if it is the 255 or not i forgot what the guy told me when i bought the tank and pump from him. the reg. is the hly-12-803bp. is this the right reg. for my app or do i need to send this one back and order a diff. is so which one do i need now? thank in advance for the help.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Feb 28, 2010
  • Feb 28, 2010
I sounds like you don't have the correct fuel pump and regulator. I never use a bypass regulator on carb applications and certinaly don't use a fuel injected pump w/ a carb either. do your self a favor and pick up a holley 150hp fuel pump and regulator, and no more wories.
T
texasmustang316
11
  • Feb 28, 2010
it got a brand new pump in it i don't have money to buy another pump.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Feb 28, 2010
  • Feb 28, 2010
if the pump puts out more than about 14 lbs of pressure, the regulator you have will not work. since it is a f.i. pump i'm almost certian it puts out 2 much pressure!
T
texasmustang316
11
  • Feb 28, 2010
i called summit and they told me i need to use the mallory fuel reg with return. it is maa-4309. so i am sendin my stuff back and exchangeing it for that one. guess i will see. the old one worked fine til i added more gas in the tank cause i ran out. but i was told to get that one cause i did have a stock fuel pump in the tank but i later found out before i hook stuff up that the old pump was dead and then found a tank full of bad gas and all rust so i bought this guys tank.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
