I replaced my clutch a while back, and did the rear main seal at the same time. The seal of course promptly started leaking, so now I have the repair sleeve to put on the crankshaft. I would prefer to only do this once. So if you have done this before, let me know what you did to get it on right. The sleeve itself is a flimsy aluminum sleeve.
Did you use any sealants between the sleeve and the crankshaft, or did you simply slide it on.
Also when you installed the new seal, did you lubricate it in any way, or simply knock it in. I have cleaned all around where the seal sits, but haven't done anything else.
I really want to get this right the second time around so let me know of any tips or tricks you may have.
Thanks
Howard
Thanks
Howard
