need cam advice
joeyd0730
130
queens, ny
i need some cam advice, i currently have a b-303 which is not working great with my application. here are the details. 91 gt convertable. t-5. 373's, bbk ssi intake, stock heads ported with crane valve springs. 1.7 rollers. s-trim vortech. 75mm throttle body. 73mm mass air, 30lb injectors. 1 7/8 shortys, 2 1/2 h-pipe with flowmasters. what cam do you think will work best with my combo. i dont care about rough idle. i am currently looking at the trickflow stage 3. e-303,f-303, x-303. thanks for any info. joe
E303 I also heard was kindof supercharger friendly, but you should go w/ a custom blower cam - but anyway, that might not be your PROBLEM - it could be your injectors are too small, and your A/F is thrown off, w/ heads cam intake, your supposed to get 24lb injectors, w/ h/c/i and a blower, your supposed to get 42#ers - now, if you only go one step up for the h/c/i, than w/o the h/c/i, you should go one step down from the 42's - making it 36's at least - what is it, 19, 24, 30, 36, 42 - you bump up 1 step for h/c/i, bump up 3 steps for supercharger w/ no H/C/I i would say -
alright i just read that you do have an intake on there as well as ported stocker heads, maybe you should go 42#ers - my bad for not reading it thoroughly the first time lol
