need cam advise for supercharged 351w
Ngc414
22
I am pulling my 302 shortblock and transplanting a 351w. I have no Idea which hydraulic cam to run. I want to run a good streetable cam. here is a rundown of my set-up:
roush Iron 200 heads
1.6 scorpion roller rockers
cobra/ gt-40 intake
351w out of a 1994 f-250
Vortech s-trim 12psi
MSD, #42injectors, trex...
best thing to do is phone comp cams tech line. Or phone lunati's tech line. they will set you up with a cam that will get close to the most out of your combo. If you don't want to do that find a custom grind shop and give them your combo. find a good shop. then you will have a cam set up specifically for your combo and it will have the power band set up for your style of driving.
Part Number 35-306-8
Engine 1982-1995 Ford
5ltr,
8cyl.
Grind Number FW 284H-R14
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.533 0.544
Duration At 0.006 Tappet Lift 284 290
Valve Timing At 0.05
Open Close
Intake 2 42
Exhaust 53 -3
These Specs Are For The Cam Installed At 110 Intake CL
Intake Exhaust
Duration At 0.05 224 230
Lobe Lift 0.333 0.34
Lobe Separation 114
Recommended Valve Springs 986-16
Dont forget to get the right valve springs for the cam. Or if you have new heads just ask them if the springs they come with are compatible.
5ltr,
8cyl.
Description
Intake Exhaust
Open Close
Intake 2 42
Exhaust 53 -3
Intake Exhaust
Lobe Separation 114
Says it's for a 5 liter V8, not 5.8 liter?
