Need clarity on mod options
  • Thread starter Thread starter jranaudo
  • Start date Start date Mar 6, 2009
J
jranaudo
10
  • Mar 6, 2009
Newbie here and before you ask yes I did search and found some things but still have other questions. I hope to be getting a used mustang soon (2005+) and am doing research into some of the first mods to keep my satisfied until it arrives.
Exhaust:
what are the many exhaust configurations? What's legal?
For example I don't even know what an x-pipe or h-pipe is and which one is better. I know Axle-back is cheapest. I know there is a mid-muffler setup as well. Also the many threads don't seem to mention whether the cats are removed or not. Also whether they are high flows cat or even legal.
Suspension
I know about the different spring types and struts types but I dont understand the control arms. Is changing the control arms required? What's the benefit?
Any info would be great so I can better understand this.
ct07gt
377
  • Mar 6, 2009
There are several exhaust options, with the most common being axle backs. An axle back is just a different muffler, or in some cases a muffler delete. They do very little to affect power and are done just for sound. As far as X and H pipes go, there are catted and off-road. Off-roads are louder and flow better because they have no cats. I am pretty sure they are not legal for street use anywhere, but unless your state tests, you should be ok. The difference between an X and H is the type of cross-over between each side of the exhaust system, the H looks like an H and the X is shaped like, you guessed it, an X. They sound different and X pipes tend to flow a little better. There are about a thousand different combinations to pick from, most people just start with an axle back.
For control arms, people are usually referring to the lower control arms, which connect the axle to the car. The stock ones tend to flex and have weak bushings. The most common problem caused by weak LCA's is axle hop. This is the axle hopping up and down during acceleration. Unless you have that problem, you can hold off on buying new ones right away.
J
jranaudo
10
  • Mar 6, 2009
hah I got it.
So lower control arms are not mandatory if I lower it but most likely will be done at some point.
NotQuik
5,158
29
88
Central Florida
Mar 6, 2009
  • Mar 6, 2009
jranaudo said:
hah I got it.
Correct, i still have stock lower control arms (LCA's) on mine and have no issues as do many on this board.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Mar 6, 2009
  • Mar 6, 2009
When you lower the car, you may need an adjustable upper control arm, (there is only one), to correct the pinion angle. Good aftermarket ones also help with the axle hop. Also, if you lower it much, you will need an adjustable panhard bar to replace the stock one; this will allow you recenter the car over the rear end after lowering.
Exhaust mods add very little power to these cars unless you spend $1500 on long tube headers and off road x or h pipe, all of which are illegal. The "x" and "h" simply refer to the shape of the pipes where they intersect under the car.
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
