need computer re-programmed...
  • Thread starter Thread starter 88hatchblack
  • Start date Start date Jun 7, 2005
88hatchblack
163
Willard, Ohio
Jun 7, 2005
  • Jun 7, 2005
where to go to get computer re-programmed...
My new motor has a 302 firing order cam, and I didn't put the longblock together- so I don't want to switch cams. Plus it's already all in the car and wired up nicely. Does anyone know where I could send my computer to get it programmed to fire the injectors in the 302 firing order instead of the HO firing order? Or could I get a chip burned? I tried switching injector wires 7&4 and 5&3, but it confused the computer because it got the reading from the O2's from the wrong bank. See sig for mods. -------------v
88hatchblack
163
Willard, Ohio
Jun 7, 2005
  • Jun 7, 2005
any information is appreciated!
88hatchblack
163
Willard, Ohio
Jun 8, 2005
  • Jun 8, 2005
can the injector firing order even be changed by re-programming the computer?
z9_87
332
Urbana, IL
Jun 8, 2005
  • Jun 8, 2005
Well it's more than the computer that controls the firing order. You will have to change the wires on the distributor around for the non-HO order. As far as the fuel injectors go... i would think that you need the chip burned for that wich will cost you a crap load more than a cam will. So go get a HO roller cam and save yourself a headache.
88hatchblack
163
Willard, Ohio
Jun 8, 2005
  • Jun 8, 2005
that's what i've decided on-- i'm just not looking forward to breaking the motor in since it's a hydraulic flat tappet
z9_87
332
Urbana, IL
Jun 10, 2005
  • Jun 10, 2005
it wont be to hard. Just get a roller cam in the HO firing order and some roller lifters maybe some roller rockers while you're at it. Although I'm pretty sure there are HO flat tappet cams if you want to go that route.
CochinoFilipino
171
CA
Jun 10, 2005
  • Jun 10, 2005
MustangsPlus put EFI on a 289. I don't see why you can't do the same with the 302. Did you change the order of the spark plug wires (or at distributor)along with the injectors wiring?
http://www.mustangsplus.com/tech/efi/index.html
CochinoFilipino
171
CA
Jun 10, 2005
  • Jun 10, 2005
Interesting thread about roller conversion from the classic forum. They estimated it cost about $600.
http://forums.stangnet.com/showthread.php?t=551782
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
Help needed - Cranks, no Start
  • sleeping93coupe
  • Nov 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 30, 2025
AeroCoupe
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
  • dan50
  • Jul 18, 2026
dan50
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
