Hey, someone with an electrical shop manual for the 70 year, I need some help.
I got the engine and trans installed completely today, and when I went for the big start up, zip, zilch, natta. I have power to the ignition side of the relay, and the coil as well. However when I have the wife turn the key to "start" I got nothing to that side of the relay.
I pulled the steering column plasitc, and exposed the wires running up the bottom of the column. None of them are hot in the start position.
What color wire is the "start" wire? Any ideas on why the thing is dead?
I need to get a ground strap from the engine to the body, but that wouldn't be it.
I am not the brightest bulb in the bunch when it comes to the electrical system, so you guys with the brains in this area, please direct me.
Thanks
Gram
Thanks
Gram
Don't forget to rehook the net saftey switch back up.
