Need emergency help for my alternator!!
andrewb_80
38
Dayton, Oh
I have a 94 That was originally a v6. I just swapped it to a carb 5.0. The alternator Im assuming is off of an 86 (Block casting #) I have a three wire plug and a one wire plug from my orig. v6. I noticed that the little white, black wire is in both plugs. The remaining two wires are white/yellow and lt blue/red. My alternator has accepts two wires in the plug hole, excluding the power and ground. How do I go about making this work?!?!?! I NEED HELP ASAP!! thanks!:notnice: :hail2: :shrug:
I dont think they are the same.... My alt looks different. It only accepts two wires, and that plug does not fit it. The alt is 86 and the wiring is 94 FYI in case it wasnt clear. Maybe a little more info would be nice!
If you are keeping the elec fan, etc on your SN, I WOULD spend the money for a 3G alternator. You will overrun the 86's alt (it has half the output that your 94's alt had). Those old alts were throwbacks to carb days (no computers, high flow fuel pumps, etc etc). Even on foxes with mech fans, they dont do too well.
However, I dont know how the wiring differs on your four-eyed alt compared to an aero fox's alt. I will defer to Daggar et al. You could search his old posts for info - he once had a really nice write up on converting as I recall.
Good luck.
