Stang8URMPRT said:
You're whole smog system runs off the steel lines that connect to the back of the heads. That is where you get all your exhaust recirculation. Exhaust comes out of there and into the smog pump and to the egr. If you do not have the cross over lines that are on the back of the heads, it's like pulling the heart out of the smog system and it will never work correctly.
Nick
Good intentions but wrong theory...
The EGR & smog are two separate systems.
The EGR picks up exhaust gases from the center exhaust ports and passes it up to passages in the lower manifold. It goes to the upper manifold and then to the EGR valve. The computer regulates the suction on the EGR valve to supply the correct amount of exhaust gas according to the current conditions. The EGR closes at WOT (wide open throttle).
The smog pump or AIR (Air Injection Reaction) system uses a vane type pump to compress air.
The first valve will cause the smog pump to pass it's output to the next valve or vent it overboard. The first valve vents the air to the atmosphere at WOT, saving power. At normal power settings, it passes air back the the second valve.
The second valve sends the air to the heads when the engine is cold and to the car converters when the engine is warm.
There is a tube with a check valve for the heads and another tube with a check valve for the cats. The check valves keep exhaust gasses from backing up into the pump when the pressure of the exhaust is higher than the pressure of the smog pump. That helps save the pump from excessive heat & pressure.
The compressed air directed to the heads combines with the unburned hydrocarbons to burn them more completely.
The air directed to the cats combines with the unburned hydrocarbons and reacts with the catalyst to convert them to water & CO2.
When everything works correctly, the end result is an engine that puts out CO2 and water vapor and very little unburned hydrocarbons in either cold or warm operation.
