Need Fuel Reg with 190 fuel pump?
Jaswir,
I'm using a 306 with stock FPR, 42# injectors, KB blowzilla 8# boost and a 190 Lh/hr pump. Works great, tuned it myself with Tweecer RT and WB02 running 12.5:1 AFR at WOT and idles at 672 RPM real nice.
Don
Don's right, even though his set up is not quite stock. ;)
if all you are changing is the pump, you can hook up whatever size pump you want and the reg will return the unneeded fuel (beauty of a return-style fuel system).
good luck.
